I try to install the temperature reporting error plugin to fix the problem with Creality printers.
I read the posts here in the forum and found the right command to install the package from Github.
I connected via SSH and logged in as pi. I put the following line into the terminal:
python3 -m pip install "https://github.com/SimplyPrint/OctoPrint-Creality2xTemperatureReportingFix/archive/master.zip"
And I get this response:
/usr/bin/python3: No module named pip
What does this mean? What can I do? I am a complete beginner with terminal and SSH.
Complete Logs
How can I access logs?
I have Octoprint 1.5.3, OctoPi 0.18.0, Python 3 and Pip 21.0.1 installed on a Raspberry Pi 3 B+
I connect via terminal from a MacBook with MacOS 10.14.
