Hello together,
I have been using Octoprint for a few weeks. On the whole, it works great.
A small problem I have from time to time, obviously a sporadic error possibly a bug. Maybe someone else has observed this problem and knows a solution or Maybe you have to report it to the developers.
When I start a print, sometimes it happens that the printer starts, but the nozzle temperature is set to 0 and the heating bed to 150°C. If I don't notice it right away, the printer stops extruding after a few minutes because the nozzle is too cold. If I start the same GCODE again, everything works fine. This does not happen all the time, but only every 5-10 prints. I have attached the system info bundle.
I do not really have an idea
No, I just read here that there must be... what restrictions does this create? I would have to use the first some time and observe whether this sporadic error is then gone.
I do not know
octoprint-systeminfo-20230402113632.zip (218.7 KB)
OctoPrint version : 1.8.7; OctoPi version : 0.18.0; RaspberryPi 4 16Gbyte; Linux raspberrypi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l; Ender3 S1 Pro; Print start via Cura plugin
Thank you very much, everyone who takes care of this.
Greetings Stefenzo
