Did a PLA preheat to unload filament from the printer control panel (not octoprint). Heated up to 215 fine, went inside to get a spool and upload the stl. Octoprint had some trouble connecting but once it did I noticed the nozzle temp jumped up to 250, you can see on the graph that the target temp was not 250.
Nothing
N/A
Complete Logs
octoprint.log: 2021-03-24 22:46:39,153 - octoprint.server.heartbeat - INFO - Server heartbeat < - Pastebin.com
Hello @Jerrkawz !
Does that appear to happen frequently?
From the graph I would say, the printer performed a shutdown/reset.
There is nothing to find in the octoprint.log concerning this. Maybe this:
2021-03-25 19:04:17,843 - octoprint.util.comm - INFO - Changing monitoring state from "Sending file to SD" to "Offline (Error: Too many consecutive timeouts, printer still connected and alive?)"
However, the temperature is dropping slowly and is back on high level in a sudden. The latter can be explained due to a re-established connection to the printer. I assume a serial connection issue.
If it actually happens more than this once, you may share the serial.log.
It only happened the one time but it was scary, i could have ended up with a bunch of burnt pla in the hotend if i wouldnt have noticed it. The target temp went to 0 after i did the filament change, it wasnt until i started a print that the nozzle temp went back down to 215 (you'll see that the target temp jumped to 215 once i restarted the print)
