After cancelling a print, the extruder and bed heaters do not turn off.
The "After print job is cancelled" GCode script contains
G1 Z300 F4000
G1 X00 Y270 F12000
M104 s0
M140 s0
This used to work. Not sure what happened.
Not sure what else to try, I added the two temperature GCode commands, as follows:
M104 s0
M140 s0
G1 Z300 F4000
G1 X00 Y270 F12000
M104 s0
M140 s0
Octoprint 1.3.10. Upgraded to 1.3.11 this morning.
OctoPi version : 0.16.0
Hypercube Evolution, Smoothieware on MKS SBASE
Attached is a plot showing the temperature. The first and second drop in target temperature were when I cancelled the print (~1 minute into a 2 minute print). The third target temorature drops were when I manually set temperature to OFF.
Octoprint.log follows:
octoprint.log (418.4 KB)
