When I type M503 ( or any other command ) into Octoprint Terminal I get the following message:-
Send: N8 M503*45
Recv: ok
Nothing more appears.
Nothing because I don't know where to start
I don't know how to do that
My system is:- Mac computer running os Big Sur, Raspberry Pi 4, Anet ET5 Pro. Cura slicer.
I can successfully print a model via Cura but I want to access the e.steps in order to change them but I am unable to do so. I am far from being technically proficient so be gentle with me.
When you wrote your post, on the right side of the edit window, there is the preview. The blue words (like safe mode) are links. They help you to find out more.
So you got a response from the printer and that shows the the terminal is working.
Why there is no report may either be a problem within the firmware or a plugin filters out the report.
When this is disabled, the firmware is not able to report the current settings. You must either enable this in your firmware build or ask wherever your firmware build is from to enable the option.
