I do not know how to connect a Rpi 3b+ w/camera to the tevo nereus because I don't have any mounts for it, and I don't know how to connect the Rpi to the printer, and connect octoprint to my wifi and run octoprint anywhere on it.
I have no clue how to do any of this stuff so could someone guide me?
n/A
latest octopi, rip 3b+, tevo nereus w/ nodded firmware (tmc 2208's on xyz and lv8729 on extruder) and I use windows/rpi
First do you run Marlin as firmware?
If yes - you just connect your printer via usb to your raspberry pi.
A copy of the quickstart guide:
Setting up OctoPi
Please follow these steps after downloading:
- Unzip the image and install the contained
.imgfile to an SD card using Etcher. Do not at any point format the SD from your Operating System, even if prompted to do so - that will break it and you’ll have to start over. Just use Etcher to flash the.imgfile, that is enough!- Configure your WiFi connection by editing
octopi-wpa-supplicant.txton the root of the flashed card when using it like a thumb drive. Important: Do not use WordPad (Windows) or TextEdit (MacOS X) for this, those editors are known to mangle the file, making configuration fail. Use something like Notepad++, Atom or VSCode instead or at the very least heed the warnings in the file. Note: This changed with OctoPi 0.15.0, earlier versions had you editoctopi-network.txtwhich has a different format. This old method is no longer supported and the contents of this file will be ignored. Just useoctopi-wpa-supplicant.txt.Please also refer take a look at the full WiFi setup guide in the FAQ that also includes Troubleshooting tips.- Boot the Pi from the card.
- Log into your Pi via SSH (it is located at
octopi.localif your computer supports bonjour or the IP address assigned by your router), default username is “pi”, default password is “raspberry”. Runsudo raspi-config. Once that is open:- Change the password via “Change User Password”
- Optionally: Change the configured timezone via “Localization Options” > “Timezone”.
- Optionally: Change the hostname via “Network Options” > “Hostname”. Your OctoPi instance will then no longer be reachable under
octopi.localbut rather the hostname you chose postfixed with.local, so keep that in mind.You can navigate in the menus using the arrow keys and Enter. To switch to selecting the buttons at the bottom use Tab. You do not need to expand the filesystem , current versions of OctoPi do this automatically. You also do not need to manually enable the RaspiCam if you have one, that is already taken care of on the image as well.- Access OctoPrint through
http://octopi.localorhttp://<your pi's ip address>. https is available too, with a self-signed certificate (which means your browser will warn you about it being invalid).Please also refer to OctoPi’s README, especially the “How to use it” section.
