I am trying to stream a modified (added circles) video-stream to the browser.
The "circle-marking" is done via open-cv. The image processing works, but now I want to stream the result to the browser. I used this tutorial:
https://blog.miguelgrinberg.com/post/video-streaming-with-flask
Because it was not working with video I tried to stream text-messages:
@octoprint.plugin.BlueprintPlugin.route('/stream')
def streamed_response(self):
def generate():
from time import sleep
yield "1"
sleep(4)
yield "2"
sleep(4)
yield "3"
return Response(generate(),mimetype='text/event-stream')
If I call this endpoint via curl I expected 1234, with four second delay between 2 and 3, but instead after eight seconds I received all numbers.
I debugged into tornado.py __call__ and it looks that the body is always a string and not a stream.
Also, I found this stackoverflow-answer: https://stackoverflow.com/questions/23232399/server-sent-events-with-flask-and-tornado/23233100#23233100
It looks like that streaming with a combination with flask and tornado is not possible.
Tornado's WSGIContainer does not support streaming responses from wsgi apps.
I tried to implement my own RequestHandler: tornado.web.RequestHandler, but then I received this error-message:
flask/globals.py", line 20, in _lookup_req_object
raise RuntimeError('working outside of request context')
RuntimeError: working outside of request context
Has anybody a solution or an idea for this?
thx, in advance
Olli
