The Classic "Offline after Error" or simply "Offline"
My Ender 3 has been running fine for two years until last week and now this.
I get the message: State: Offline after error
No more candidates to test, and no working port/baudrate combination detected.
I also have the blue screen of death which I have added the firmware:
Ender-3 Pro_4.2.2_Firmware_Marlin2.0.1 - V1.0.1.bin
and still nothing. Its a mess!
I have switched USB's per past similar instances and even change the power supply too.
I hope this is the correct log, I'm novice when it comes to this stuff.
2022-04-27 09:17:41,439 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2022-04-27 09:17:41,452 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2022-04-27 09:17:41,453 - octoprint.server - INFO - OctoPrint 1.7.3
2022-04-27 09:17:41,457 - octoprint.plugin.core - INFO - 18 plugin(s) registered with the system:
|  Action Command Notification Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_notification
|  Action Command Prompt Support (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/action_command_prompt
|  Announcement Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/announcements
|  Anonymous Usage Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/tracking
|  Application Keys Plugin (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/appkeys
|  Backup & Restore (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/backup
|  Core Wizard (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/corewizard
|  Discovery (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/discovery
|  Error Tracking (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/errortracking
|  Event Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/eventmanager
|  File Check (2021.2.23) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_file_check
|  Firmware Check (2021.10.11) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_firmware_check
|  GCode Viewer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/gcodeviewer
|  Logging (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/logging
|  Pi Support Plugin (2022.3.1) (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint_pi_support
|  Plugin Manager (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/pluginmanager
|  Software Update (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/softwareupdate
|  Virtual Printer (bundled) = /home/pi/oprint/lib/python3.7/site-packages/octoprint/plugins/virtual_printer
2022-04-27 09:17:41,519 - octoprint.environment - INFO - Detected environment is Python 3.7.3 under Linux (linux). Details:
|  hardware:
|    cores: 4
|    freq: 1400.0
|    ram: 914006016
|  os:
|    bits: 32
|    platform: linux
|  plugins:
|    pi_support:
|      model: Raspberry Pi 3 Model B Plus Rev 1.3
|      octopi_version: 0.18.0
|      octopiuptodate_build: 0.18.0-1.7.3-20220323100241
|      throttle_state: '0x0'
|  python:
|    pip: 20.3.3
|    version: 3.7.3
|    virtualenv: /home/pi/oprint
2022-04-27 09:17:41,519 - octoprint.server - INFO - ------------------------------------------------------------------------------
2022-04-27 09:20:15,434 - octoprint.plugins.softwareupdate - INFO - Fetching check overlays from https://plugins.octoprint.org/update_check_overlay.json
2022-04-27 09:20:17,831 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python3 -m pip" as command to invoke pip
2022-04-27 09:20:17,834 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python3.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2022-04-27 09:20:17,835 - octoprint.util.pip - INFO - ==> pip ok -> yes
2022-04-27 09:20:18,196 - octoprint.server.util.flask.PreemptiveCache - INFO - Adding entry for / and {'path': '/', 'base_url': 'http://192.168.86.234/', 'query_string': 'l10n=en', '_timestamp': 1651076418.1963778, '_count': 1}
2022-04-27 09:20:30,244 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.86.34
2022-04-27 09:20:47,355 - octoprint.access.users - INFO - Logged in user: Justin1923
2022-04-27 09:20:47,357 - octoprint.server.api - INFO - Actively logging in user Justin1923 from ::ffff:192.168.86.34
2022-04-27 09:20:47,605 - octoprint.server.util.sockjs - INFO - User Justin1923 logged in on the socket from client ::ffff:192.168.86.34
2022-04-27 09:20:48,654 - octoprint.plugins.announcements - INFO - Loaded channel _important from https://octoprint.org/feeds/important.xml in 0.6s
2022-04-27 09:20:49,355 - octoprint.plugins.announcements - INFO - Loaded channel _releases from https://octoprint.org/feeds/releases.xml in 0.59s
2022-04-27 09:20:50,038 - octoprint.plugins.announcements - INFO - Loaded channel _blog from https://octoprint.org/feeds/octoblog.xml in 0.64s
2022-04-27 09:20:50,862 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from https://plugins.octoprint.org/feed.xml in 0.78s
2022-04-27 09:20:51,533 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from https://octoprint.org/feeds/octopi.xml in 0.61s
2022-04-27 09:20:52,745 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2022-04-27 09:20:53,363 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2022-04-27 09:22:34,413 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 309, 'printer_state': 'OFFLINE'}
2022-04-27 09:22:35,048 - octoprint.plugins.tracking - INFO - Sent tracking event pong, payload: {'version': '1.7.3', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1400.0, 'ram': 914006016, 'pi_model': 'Raspberry Pi 3 Model B Plus Rev 1.3', 'octopi_version': '0.18.0', 'plugins': ''}
2022-04-27 09:22:35,640 - octoprint.plugins.tracking - INFO - Sent tracking event startup, payload: {'version': '1.7.3', 'os': 'linux', 'bits': 32, 'python': '3.7.3', 'pip': '20.3.3', 'cores': 4, 'freq': 1400.0, 'ram': 914006016, 'pi_model': 'Raspberry Pi 3 Model B Plus Rev 1.3', 'octopi_version': '0.18.0'}
2022-04-27 09:24:48,382 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial connection"
2022-04-27 09:24:48,441 - octoprint.util.comm - INFO - Serial detection: Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2022-04-27 09:24:48,442 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 115200
2022-04-27 09:24:48,443 - octoprint.util.comm - INFO - Connecting to port /dev/ttyUSB0, baudrate 115200
2022-04-27 09:24:48,538 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-04-27 09:24:48,542 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:24:50,546 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-04-27 09:24:50,558 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:24:52,563 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-04-27 09:24:52,573 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:24:54,575 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 250000
2022-04-27 09:24:54,584 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-04-27 09:24:54,591 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:24:56,594 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-04-27 09:24:56,603 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:24:58,606 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-04-27 09:24:58,615 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:00,618 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 230400
2022-04-27 09:25:00,620 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-04-27 09:25:00,631 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:02,633 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-04-27 09:25:02,639 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:04,641 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-04-27 09:25:04,650 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:06,653 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 57600
2022-04-27 09:25:06,655 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-04-27 09:25:06,669 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:08,671 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-04-27 09:25:08,681 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:10,684 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-04-27 09:25:10,696 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:12,699 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 38400
2022-04-27 09:25:12,701 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-04-27 09:25:12,712 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:14,714 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-04-27 09:25:14,724 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:16,726 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-04-27 09:25:16,738 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:18,739 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 19200
2022-04-27 09:25:18,742 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-04-27 09:25:18,752 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:20,756 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-04-27 09:25:20,768 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:22,771 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-04-27 09:25:22,780 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:24,782 - octoprint.util.comm - INFO - Serial detection: Trying port /dev/ttyUSB0, baudrate 9600
2022-04-27 09:25:24,784 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #1 with timeout 2.0s
2022-04-27 09:25:24,794 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:26,798 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #2 with timeout 2.0s
2022-04-27 09:25:26,807 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:28,809 - octoprint.util.comm - INFO - Serial detection: Handshake attempt #3 with timeout 2.0s
2022-04-27 09:25:28,818 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2022-04-27 09:25:30,820 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial connection" to "Error"
2022-04-27 09:25:30,859 - octoprint.util.comm - INFO - Changing monitoring state from "Error" to "Offline after error"
2022-04-27 09:25:30,897 - octoprint.plugins.action_command_notification - INFO - Notifications cleared
2022-04-27 09:25:31,482 - octoprint.plugins.tracking - INFO - Sent tracking event commerror_autodetect, payload: {'commerror_text': 'No more candidates to test, and no working port/baudrate combination detected.'}
2022-04-27 09:27:12,639 - octoprint.filemanager.analysis - INFO - Starting analysis of local:CE3_cis-boards1.gcode
2022-04-27 09:27:12,641 - octoprint.filemanager.analysis - INFO - Invoking analysis command: /home/pi/oprint/bin/python3 -m octoprint analysis gcode --speed-x=6000 --speed-y=6000 --max-t=10 --throttle=0.0 --throttle-lines=100 --bed-z=0.0 /home/pi/.octoprint/uploads/CE3_cis-boards1.gcode
2022-04-27 09:27:19,791 - octoprint.filemanager.analysis - INFO - Analysis of entry local:CE3_cis-boards1.gcode finished, needed 7.15s
2022-04-27 09:32:41,440 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2022-04-27 09:37:34,383 - octoprint.plugins.tracking - INFO - Sent tracking event ping, payload: {'octoprint_uptime': 1209, 'printer_state': 'OFFLINE'}
Google Hub Model: H2D
RaspberryPi 3b +
Do you use the tape on the 5V pin mod?
If yes is it possible that the tape has moved and is blocking a data pin?
I just removed the Kasa Smart W-Fi Plug Mini and it works now! Why would that prevent everything from working when I have had this type of setup for the past year?
I did read the article about the tape option and did that too.
Thanks for the suggestion and hope this helps someone else in the future as an option that Smart plugs might be blocking somehow the overall connection?
