"unable to connect" error when trying to change any haproxy settings or connect via port 443
Tried following this guide OctoPrint doesn't work when connecting via HTTPS
Added
reqadd X-Scheme:\ https if { ssl_fc }
to haproxy.conf.
added schemeFallback:https to config.yaml.
Logs (octoprint.log, serial.log or output on terminal tab, browser error console ...)
Additional information about your setup (OctoPrint version, 1.3.11
I tried to search the Internet for a humorous graphic for "cough up a log" but alas, could not find one. And humor was not had that day...
So... when trying to reach your OctoPrint instance via https did you get a 404 or a 401 (sounds like the latter)?
2019-09-15 06:21:57,576 - tornado.access - WARNING - 401 POST /api/login (::ffff:10.0.0.63) 26.48ms
So we might assume that name resolution worked, that it found the haproxy instance... things happened... and then it threw a 401.
I'm not sure, because Firefox just gives me a generic "Unable to connect" error.
I'm not sure about what would throw a 401 but it's entirely possible that the credentials were entered incorrectly for the login page...?
It doesn't even get to the login page.
Perhaps someone else knows more about haproxy... @foosel
