The OctoPrint server is currently not running - 1.4.0
*Octoprint Server Not Starting
**update Pi software, see if process is running (its not)Octoprint.log (2.5 KB) **
Additional information about your setup (OctoPrint version - 1.4.0, OctoPi version-.17, printer, firmware-prusa mk3s 3.18, browser-chrome, operating system-Raspi 4 octopi, ... as much data as possible)
thei started after I updated ToughHI helper .0.0.3 to fix the login issue - this has happened on two of my MK3s machines running the SAME hardware
Looks like TouchUI broke it then, maybe open an issue in it's repo?
But based on this specific ticket....if you manually edited your config.yaml file you may have corrupted it. Verify the spacing is the same relative to the other settings, it may not be 4 spaces for each indentation, but might be 2 spaces instead.
Nailed it! thank you - the spacing in my config.yaml was wrong - fixed per this post
https://github.com/BillyBlaze/OctoPrint-TouchUI/issues/370#issuecomment-596077014
