Good Day all,
I am getting this error when trying to connect to Octoprint. Have rebooted a few times but it does not help.
How can i see what the problem is ?
Good Day all,
Hello @hattinid !
Have you followed the instructions on that site?
BTW: If you need help, you should use the sub-forum Get Help (I moved it for you)
HI Thank you for the reply. i tried that but i am using Putty. So none of these command worked.
wut?
why shouldn't they work with putty?
I am not sure. But they do not work at all
please upload a screenshot so I can see what happened
you can see on the above command nothing happens
weird
well you could try to ssh into the pi via cmd or powershell
Please also create systeminfo bundle with
~/oprint/bin/octoprint systeminfo .
(the dot is important) and upload it here
You can download it with WinSCP
weird indeed, too many inline greps?
I followed your steps to do it via cmd. Then i copied and pasted the command from the page and still it does nothing just like in Putty
Maybe i am just not IT literate enough ......... haha
permission denied is an odd one, but you wouldn't be able to call the file directly anyway to open. You'd have to use the command nano ~/.octoprint/logs/octoprint.log to open it in an editor to read.
Permission denied is what you get when you don't use any command
