Seeing " The OctoPrint server is currently not running" screen.
The suggested
pi@bender:~ $ ps -ef | grep -i octoprint | grep -i python
command doesn't do anything.
Logging in via PuTTY gives the following:
Error processing line 1 of /home/pi/oprint/lib/python3.9/site-packages/_virtualenv.pth:
Fatal Python error: init_import_site: Failed to import the site module
Python runtime state: initialized
File "/usr/lib/python3.9/site.py", line 175, in addpackage
exec(line)
File "", line 1, in
File "/home/pi/oprint/lib/python3.9/site-packages/_virtualenv.py", line 40, in
from functools import partial
File "/usr/lib/python3.9/functools.py", line 18, in
from collections import namedtuple
ImportError: cannot import name 'namedtuple' from 'collections' (unknown location)During handling of the above exception, another exception occurred:
File "/usr/lib/python3.9/site.py", line 606, in
main()
File "/usr/lib/python3.9/site.py", line 589, in main
known_paths = venv(known_paths)
File "/usr/lib/python3.9/site.py", line 521, in venv
addsitepackages(known_paths, [sys.prefix])
File "/usr/lib/python3.9/site.py", line 376, in addsitepackages
addsitedir(sitedir, known_paths)
File "/usr/lib/python3.9/site.py", line 214, in addsitedir
addpackage(sitedir, name, known_paths)
File "/usr/lib/python3.9/site.py", line 185, in addpackage
import traceback
File "/usr/lib/python3.9/traceback.py", line 5, in
import linecache
File "/usr/lib/python3.9/linecache.py", line 8, in
import functools
Access OctoPrint from a web browser on your network by navigating to any of:
http://bender.local http://10.1.15.8https is also available, with a self-signed certificate.
This image comes without a desktop environment installed because it's not
required for running OctoPrint. If you want a desktop environment you can
install it viasudo /home/pi/scripts/install-desktop
OctoPrint version : unknown
OctoPi version : 1.0.0
Rebooted RasPi - same result.
Complete wipe and fresh reinstall of OctoPrint 1.8.7 from RasPi Imager - appeared to work fine for a few days, but now (logging in for first time in a couple of weeks) back to not running again.
Attempted to force reinstall - gives exactly the same block of error messages as above:
pi@bender:~ $ ~/oprint/bin/pip install --force-reinstall OctoPrint==1.8.7 --no-cache-dir
etc
etc
Tried:
pi@bender:~ $ octoprint safemode
-bash: octoprint: command not found
Tried:
pi@bender:~ $ octoprint config set --bool server.startOnceInSafeMode true
n/a - couldn't get it to run.
Can't get at bundle as can't log in to OctoPrint.
Retrieved latest log using WinSCP: octoprint.log (10.1 KB)
OctoPrint 1.8.7, OctoPi 1.0.0, Prusa MK3 fw3.10.0, Raspberry Pi 3 Model B Plus Rev 1.3
Not sure if this is a python bug (not seeing anyone else complaining of the same thing) - is it more likely a corrupted SD card - i.e. just try another? Any suggestions much appreciated.
Kind regards,
Jo
