The OctoPrint server is currently not running
If you just started up your Raspberry Pi, please wait a couple of seconds, then try to refresh this page.
If the issue persists, please log into your Raspberry Pi via SSH and check the following:
- Verify that the process is running:
ps -ef | grep -i octoprint | grep -i pythonshould show a python process:
pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python
pi 1441 1 6 11:12 ? 00:00:15 /home/pi/oprint/bin/python
/home/pi/oprint/bin/octoprint --host=127.0.0.1 --port=5000
- If it isn't, the question is why. Take a look into
~/.octoprint/logs/octoprint.log, there might be an error logged in there that helps to determine what's wrong. - You might also want to try if you can restart the server (if no obvious error is visible):
sudo service octoprint restart.
If all that doesn't help to trouble shoot the issue, you can seek support on the OctoPrint Community Forum. Please provide your OctoPi and OctoPrint versions as well as your octoprint.log and explain what you already tried and observed as detailed as possible.
- the directions above
- /home/pi/oprint/bin/octoprint serve
2022-11-27 12:42:19,287 - octoprint.settings - ERROR - Could not write test file to /home/pi/.octoprint/logs/.testballoon.txt
OSError: [Errno 28] No space left on device
During handling of the above exception, another exception occurred:
File "/home/pi/oprint/lib/python3.7/site-packages/octoprint/settings.py", line 2396, in _validate_folder
f.write("test")
2022-11-27 12:42:19,290 - octoprint.startup - CRITICAL - Could not initialize settings manager: Folder at /home/pi/.octoprint/logs doesn't appear to be writable, please fix its permissions
2022-11-27 12:42:19,290 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
Gather logs with ~/.octoprint/logs/octoprint.log and got "Permission denied"
~/oprint/bin/octoprint systeminfo
There was a fatal error initializing the platform.
I can't access the system, so I dont know how to restart in safe mode
I have 2 pis, because I can't access this one, I will assume all the information is the same from my other pi.
OctoPrint 1.8.6
Python 3.7.3
OctoPi 0.18.0
I installed everything myself about 2 months ago, I know at a minimum it has bed mesh visualizer. I just don't remember if I installed any other add-ons.
I had finished a print over night, and when I went to do another print, I received that error
