After updating the filamentmanager update, server restarted and i got tha message.
I have tried to force install the plugin and nothing happened.
After that i have tried a solution i found here (turn to safe mode and delete a file from the plugin folder),
Nothing happened also and the plugin folder was empty already
yes
no. I am pretty sure that it doesn't turm to safe mode cause i get the same message at my browser: "The octoprint server is currently not running"
Linux octopi 5.10.17-v7l+ #1421 SMP Thu May 27 14:00:13 BST 2021 armv7l GNU/Linux
log file
The last entries in the log are from 2021-11-16, followed by a lot of corrupted-looking stuff. So something is wrong that means it can't start up properly.
Presumably you have SSH access to the Pi to get the log file etc. already. So from SSH, if you run ~/oprint/bin/octoprint serve do you get any output?
2021-11-19 19:00:10,773 - octoprint.startup - CRITICAL - Could not initialize settings manager: Error parsing the configuration file /home/pi/.octoprint/config.yaml, it is invalid YAML. The parser reported an error on line 201, column 1.
There was a fatal error starting up OctoPrint.
2021-11-19 19:00:10,774 - octoprint.startup - CRITICAL - There was a fatal error starting up OctoPrint.
Ok, that gives us something to work with. It means there's a problem with your config.yaml file. Don't post it here as it contains secrets, but you might want to open it to see what the problem on line 201 is. It might have ended up the same as the log file, with corruption in it.
