The octoprint server is currently not running error
~/oprint/bin/pip install --force-reinstall --no-cache-dir octoprint
yes
didnt run
cant dump systeminfo for same reason as above
octoprint.log (131.7 KB)
kern.log.1 and syslog.1 filled up the sd card
this line seems to have many entries in both logs
May 25 13:36:43 octopi kernel: [ 4430.080021] brcmfmac: brcmf_sdio_htclk: HT Avail request error: -5
first of all - just delete those files.
now to the error: it's the integrated wifi driver.
Maybe this was a one time exception and it won't happen ever again.
I would delete the files and keep an eye on the logs.
Btw did you get any undervoltage warnings before that happened? Because that could be the cause.
No, Ive never seen any on this machine. I'll monitor the logs over the next few days and see if its reoccuring at any stage. Thanks
system
Closed
6
