i have tried Safe mode but it does nothing at all
In what way?
It should disable all 3rd party plugins.
i can't confirm this because i get the same message about octoprint server.....
Also the folder plugins is completely empty
But the log should be a bit more skinny
This is the code in config.yaml
server:
startOnceInSafeMode: true
commands:
serverRestartCommand: sudo service octoprint restart
systemRestartCommand: sudo shutdown -r now
systemShutdownCommand: sudo shutdown -h now
firstRun: false
incompleteStartup: true
onlineCheck:
enabled: true
pluginBlacklist:
enabled: true
Really i have no idea.
It doesn't look like you have the same issue if it is not solved by the same problem.
It would probably be better to create a new 'Get Help' topic so that we can specifically look at your problem.
