Yesterday I updated to the latest octoprint version through the GUI interface. Everything was working just fine until today. When I tried to access the page today I got the "The OctoPrint server is currently not running" error
I tried the suggested commands
pi@octopi:~ $ ps -ef | grep -i octoprint | grep -i python
pi@octopi:~ $
Also I tried the following:
pi@octopi:~ $ /home/pi/oprint/bin/pip install https:// get.octoprint.org/latest
DEPRECATION: Python 2.7 will reach the end of its life on January 1st, 2020. Please upgrade your Python as Python 2.7 won't be maintained after that date. A future version of pip will drop support for Python 2.7.
Looking in indexes: https:// pypi.org/simple, https:// www.piwheels.org/simple
Collecting https:// get.octoprint.org/latest
Downloading https:// get.octoprint.org/latest (5.4MB)
|ββββββββββββββββββββββββββββββββ| 5.4MB 73kB/s
ERROR: Complete output from command python setup.py egg_info:
ERROR: Traceback (most recent call last):
File "<string>", line 1, in <module>
File "/tmp/pip-req-build-PR7NL9/setup.py", line 231, in <module>
setup(**params())
File "/usr/lib/python2.7/distutils/core.py", line 111, in setup
_setup_distribution = dist = klass(attrs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/dist.py", line 264, in __init__
for ep in pkg_resources.iter_entry_points('distutils.setup_keywords'):
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources.py", line 504, in iter_entry_points
entries = dist.get_entry_map(group)
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources.py", line 2478, in get_entry_map
self._get_metadata('entry_points.txt'), self
File "/home/pi/oprint/local/lib/python2.7/site-packages/pkg_resources.py", line 2255, in parse_map
raise ValueError("Entry points must be listed in groups")
ValueError: Entry points must be listed in groups
ERROR: Command "python setup.py egg_info" failed with error code 1 in /tmp/pip-req-build-PR7NL9/
and also I issued the following commands:
15 pip install https:// get.octoprint.org/latest <-FAILED
16 ~/oprint/bin/pip install setuptools==7.0
17 pip install https:// get.octoprint.org/latest <- FAILED
18 ~/oprint/bin/pip install --upgrade pip
19 apt-get update
20 sudo apt-get update
21 sudo apt-get dist-upgrade -y
22 sudo apt-get upgrade -y
23 sudo reboot
24 pip install https:// get.octoprint.org/latest <- FAILED
OctoPrint version : 1.3.11
OctoPi version : 0.16.0
pi@octopi:~ $ sudo cat ~/.octoprint/logs/octoprint.log
[sudo] password for pi:
2019-05-16 17:08:23,482 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 17:08:23,487 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2019-05-16 17:08:23,488 - octoprint.server - INFO - OctoPrint 1.3.11
2019-05-16 17:08:23,496 - octoprint.plugin.core - INFO - 21 plugin(s) registered with the system:
| Enclosure Plugin (4.12) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_enclosure
| Octolapse (0.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| PrintTimeGenius Plugin (1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_PrintTimeGenius
| Sidebar Temp Graph (0.1.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_sidebartempgraph
| Tab Order (0.5.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_taborder
| Themeify (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2019-05-16 17:08:23,523 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
2019-05-16 17:08:23,523 - octoprint.server - INFO - ------------------------------------------------------------------------------
2019-05-16 17:23:23,485 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 17:38:23,487 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 17:53:23,491 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 18:08:23,494 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 18:23:23,498 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 18:38:23,500 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 18:53:23,502 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 19:08:23,506 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 19:23:23,509 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 19:38:23,512 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 19:53:23,514 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 20:08:23,516 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 20:23:23,519 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 20:38:23,522 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 20:53:23,526 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 21:08:23,529 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 21:23:23,532 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 21:38:23,535 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 21:53:23,539 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 22:08:23,542 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 22:23:23,545 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 22:38:23,549 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 22:53:23,551 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 23:08:23,554 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 23:23:23,557 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 23:38:23,560 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-16 23:53:23,563 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 00:08:23,566 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 00:23:23,569 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 00:38:23,572 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 00:53:23,575 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 01:08:23,577 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 01:23:23,580 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 01:38:23,583 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 01:53:23,587 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 02:08:23,590 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 02:23:23,594 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 02:38:23,596 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 02:53:23,599 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 03:08:23,602 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 03:23:23,606 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 03:38:23,609 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 03:53:23,613 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 04:08:23,615 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 04:23:23,617 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 04:38:23,621 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 04:53:23,623 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 05:08:23,626 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 05:23:23,629 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 05:38:23,631 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 05:53:23,634 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 06:08:23,638 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 06:23:23,640 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 06:38:23,643 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 06:53:23,645 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 07:08:23,648 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 07:23:23,650 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 07:38:23,653 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 07:53:23,655 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 08:08:23,657 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2019-05-17 08:23:23,660 - octoprint.server.heartbeat - INFO - Server heartbeat <3
