I have installed octoprint on my Raspberry pie 3 B V1.2, got it to connect to wifi (using notepad++ to edit the file), managed to login to SSH, but each time I test the server (8.8.8.8, port 53) it says the server is not reachable.
I have re-installed (flashed) the SD card 5 or 6 times now, the last 2 times I deleted the octopirnt files and downloaded them again (zip file) from the website. I have tried connecting via an Ethernet cable (which is normally connected to a PC which is able to get on the internet).
octoprint.log (33.0 KB)
I am trying to use WiFi to connect (which seem to work as I can login to the web interface through the octoprint IP address (it also comes up in the network page on file explorer.
I am using windows 10 for my system, I am using chrome for the web brouser, I am using Putty to connect via SSH (although I can log in, SSH is a bit beyond my skill set at the moment).
The router is a brand new out of the bow router from my IPS 'EE' in the UK. It is called an 'EE smart HUB'. It was installed about a week ago.
The raspberry pi is connected to power with a 2.5 Amp power supply.
All other WiFi enabled devices are able to connect to the internet through this router.
Iv been reading through the forums and seen that it is possible to try different server settings, but I am unsure what the other options would be, I did a google for different options but didn't see anything specifically related to octoprint that had alternatives with port numbers.
Any help would be greatly appreciated.
