I have a Anet a8 running octoprint on raspberry pi. Just lately I have had an issue that after printing approximately 15-20 minutes Octoprint shuts down my print for a bed thermal runaway. I have checked all my hardware external MOSFET, Thermistor, and connections and all are fine. I also tried printing a file that I printed just prior to this problem with the same results. I can set a Temperature on the bed without loading a print and it will stay just fine. I even left it that way for an hour and didn't have a problem.
I disconnected the Pi and printed from SD card keeping an eye on the temperatures and the Printer printed just fine and the temps stayed constant.
Here is a screen shot of the temperature graph at the time of shutdown.
I am running the Latest version
2018-11-16 02:35:56,809 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918192128
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: 3B
| revision: a22082
| version: 0.15.1
| python:
| pip: 9.0.3
| version: 2.7.13
| virtualenv: /home/pi/oprint
2018-11-16 02:35:56,821 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-11-16 02:35:56,839 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-11-16 02:35:57,115 - octoprint.server - INFO - Shutting down intermediary server...
2018-11-16 02:35:57,589 - octoprint.server - INFO - Intermediary server shut down
2018-11-16 02:35:57,592 - octoprint.events - INFO - Processing startup event, this is our first event
2018-11-16 02:35:57,593 - octoprint.events - INFO - Adding 0 events to queue that were held back before startup event
2018-11-16 02:35:57,595 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-11-16 02:35:57,609 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-11-16 02:35:57,768 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Detecting serial port"
2018-11-16 02:35:57,795 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _http._tcp
2018-11-16 02:35:57,807 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting serial port" to "Opening serial port"
2018-11-16 02:35:57,810 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Detecting baudrate"
2018-11-16 02:35:57,813 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _octoprint._tcp
2018-11-16 02:35:57,819 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2018-11-16 02:35:57,828 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2018-11-16 02:35:57,926 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-11-16 02:35:58,248 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://wildvortexprint.asuscomm.com/'}
2018-11-16 02:35:58,820 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-11-16 02:35:58,835 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2018-11-16 02:35:58,917 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from https://plugins.octoprint.org/plugins.json
2018-11-16 02:36:00,151 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.1
2018-11-16 02:36:00,408 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2018-11-16 02:36:00,655 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from https://plugins.octoprint.org/notices.json
2018-11-16 02:36:02,376 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.1
2018-11-16 02:36:21,178 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-11-16 02:36:22,074 - octoprint.server.preemptive_cache - INFO - ... done in 23.83s
2018-11-16 02:36:22,075 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://97.82.200.220/'}
2018-11-16 02:36:22,385 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-11-16 02:36:23,455 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-11-16 02:36:24,769 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-11-16 02:36:26,096 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-11-16 02:36:26,741 - octoprint.util.comm - INFO - Changing monitoring state from "Detecting baudrate" to "Operational"
2018-11-16 02:36:26,747 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-11-16 02:36:26,759 - octoprint.plugins.firmwareupdater - INFO - Got CONNECTED event
2018-11-16 02:36:26,762 - octoprint.plugins.firmwareupdater - INFO - Run postflash flag is not set
2018-11-16 02:36:26,927 - octoprint.util.comm - INFO - Printer reports firmware name "Marlin 1.1.8 (Github)"
2018-11-16 02:36:26,942 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2018-11-16 02:36:26,983 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2018-11-16 02:36:27,002 - octoprint.util.comm - INFO - Firmware states that it supports temperature autoreporting
2018-11-16 02:36:29,124 - octoprint.server.preemptive_cache - INFO - ... done in 7.05s
2018-11-16 02:39:53,379 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2018-11-16 02:39:53,396 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-11-16 02:50:50,334 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-11-16 02:55:04,324 - octoprint.util.comm - WARNING - Received an error from the printer's firmware: Thermal Runaway, system stopped! Heater_ID: bed
| Last lines in terminal:
| Send: N4597 G1 X55.403 Y87.859 E11.2320*82
| Recv: ok
| Send: N4598 G1 X59.470 Y91.926 E11.4580*81
| Recv: ok
| Send: N4599 G1 X59.903 Y91.723 E11.4768*86
| Recv: ok
| Send: N4600 G1 X55.836 Y87.656 E11.7027*85
| Recv: ok
| Send: N4601 G1 X56.269 Y87.453 E11.7215*83
| Recv: ok
| Send: N4602 G1 X60.337 Y91.520 E11.9475*83
| Recv: ok
| Send: N4603 G1 X60.770 Y91.317 E11.9663*82
| Recv: ok
| Send: N4604 G1 X56.703 Y87.250 E12.1923*81
| Recv: ok
| Send: N4605 G1 X57.136 Y87.046 E12.2111*94
| Recv: ok
| Send: N4606 G1 X61.203 Y91.114 E12.4371*94
| Recv: Error:Thermal Runaway, system stopped! Heater_ID: bed
2018-11-16 02:55:04,326 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Error: Thermal Runaway, system stopped! Heater_ID: bed"
Hope this is helpful, I can't make a whole lot of sense of it exceptThe thermal runaway erors and G1 positioning.
