Getting this error on connecting to a SKR v1.3 with Marlin 2.0 bugfix
Your printer's firmware is known to lack mandatory safety features (e.g.
thermal runaway protection). This is a fire risk.
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders #define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed
//#define THERMAL_PROTECTION_CHAMBER // Enable thermal protection for the heated chamber
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, what kind of hardware precisely, ...)
First time startup on bench without anything but pi connected to SKR. First 3d printer build and configuration with 2.0. Would this error be normal for hotend or bed connected.
Your firmware might have the same signature as a firmware which is on the list of known devices which are missing this future.
To test if thermal runaway protection is enabled on your printer, you can disconnect the heater element of the hotend or the heated bed while printing a print or sending temperature commands to the printer over USB using a terminal to send commands directly to the printer. You can disconnect the heater element while the printer is cold (before start) and also when the heater element is heating up. No heating of the nozzle will take place, so after the period defined by the time constant set in the firmware, the printer will halt if thermal runaway protection is enabled. Power down the machine and reconnect the wires, it is not advised to put them back in on a running machine, as one might touch the open wires; when the printer halted, you should power down or reset the printer anyways. If the printer did not halt, power it down as quickly as possible - TRP is disabled.
(text copied)
You do what it says. Open the Settings in OctoPrint, navigate to "Serial Connection", check "Log communication to serial.log". Then reproduce and share the resulting serial.log.
Thermal Runaway Protection is not enabled in the firmware: 2019-10-08 12:20:38,411 - Recv: Cap:THERMAL_PROTECTION:0
Then, autolevel is not enabled: 2019-10-08 12:20:38,156 - Recv: Cap:AUTOLEVEL:0
Therefore M420 makes no sense (also as @Schnello mentioned, there is an error in that line, there should be a space before the V)
For the same reason (no autolevel), M851 does not work too.
It was my understanding that all I had to do was uncomment the above lines in configuration.h. Eventually I will want auto leveling and again not sure where that is coming from. Thanks
Just a hunch, but try to also configure it for the chamber, even if you don't have one. I remember a similar case with a non existing bed which wasn't properly handled in the protection reporting code.
You don't say what printer you are using so I will assume an Ender 3 for the sake of this discussion.
OctoPrint uses the value found in "STRING_CONFIG_H_AUTHOR" in the firmware to determine what firmware is being used. In the case of the Ender the value is "Ender 3" which is taken to mean the default firmware which does not support therminal runaway. Changing this value to almost anything else should prevent the error.
If you are using a different printer, check the above URL for what OctoPrint is looking for.
