Information re : Thermal Runaway plugin causing M112 error with release 1.6.1, this plugin in was working fine on previous release.
start in safe mode - re enable plugins one at a time , leave out thermal runaway = problem solved , i like the idea of thermal runaway protection though can it be fixed
yes
yes
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
Octopi 1.61, Creality CR 10 V2
Have you reported the issue to the plugin author?
no , didnt know what the process was i will contact him thanks
It looks like there may already be a bug report open, if you have anything to say jump in here:
opened 06:34PM - 16 May 21 UTC
bug
**Describe the bug**
Printer gets M112 shutdown command some seconds after prin⦠t job started
**To Reproduce**
Steps to reproduce the behavior:
1. Start a print job
**Expected behavior**
Print job will be performed
**Screenshots**
Output from Octoprint.log:
2021-05-16 20:21:40,905 - octoprint.plugins.detailedprogress - INFO - Printing started. Detailed progress started.
2021-05-16 20:21:40,948 - octoprint.plugins.action_command_notification - INFO - Got a notification: Bed Heating...
2021-05-16 20:21:41,952 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:42,600 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:42,944 - octoprint.util.comm - INFO - Printer seems to support the busy protocol, will adjust timeouts and set busy interval accordingly
2021-05-16 20:21:42,952 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:43,953 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:44,601 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:44,952 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:45,953 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:46,601 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:46,953 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:47,954 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:48,607 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:48,953 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:49,954 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:50,601 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:50,912 - octoprint.plugins.detailedprogress - INFO - Message: Good accuracy
2021-05-16 20:21:50,953 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:51,954 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:52,601 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:52,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:53,961 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:54,602 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:54,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:55,961 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:56,602 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:56,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:57,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:58,600 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:58,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:21:59,960 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:22:00,602 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:22:00,915 - octoprint.plugins.detailedprogress - INFO - Message: Good accuracy
2021-05-16 20:22:00,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:22:01,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:22:02,602 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:22:02,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount == 1 for B
2021-05-16 20:22:03,958 - octoprint.plugins.ThermalRunaway - WARNING - thermalLowCount > 2 for B
2021-05-16 20:22:03,959 - octoprint.util.comm - INFO - Force-sending M112 to the printer
2021-05-16 20:22:03,992 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Offline after error"
2021-05-16 20:22:04,002 - octoprint.plugins.ThermalRunaway - CRITICAL - Thermal Runaway (under temp) caught on heater B. Reported temp is 34.17, set temp is 60.0
**Environment information:**
- Octoprint Version: 1.6.1
- Browser: Chrome
- Python Version: 3.7.3
- Operating system that Octoprint is running on: OctoPi 0.18.0
**Additional context**
Mega Zero V2.0 with SKR mini mz, BLTouch and BTT Smart Filament Sensor
I just had the same problem. It was driving me nuts trying to figure out if it was a hardware or software problem. Just uninstalled the thermal runaway plugin from my Octopi and that seems to have solved the issue.
