We made a system gcode command where a led is blinking for 30 sec.:
#!/bin/bash
API_KEY=B9735C4DAD594499B5ACC7BFD2A96306
sleep 0.1
for i in {1..30}
do
curl -H "Content-Type: application/json" -H "X-Api-Key:$API_KEY" -X POST -d "{ "command" : "ENC O2 S1" }" http://localhost/api/printer/command
sleep 0.5
curl -H "Content-Type: application/json" -H "X-Api-Key:$API_KEY" -X POST -d "{ "command" : "ENC O2 S0" }" http://localhost/api/printer/command
sleep 0.5
done
exit 0
called it OCTO4
When we execute OCTO4 through terminal it works like a charm.
When we put OCTO4 in the pause gcode it does nothing for 30 seconds and then blinks 30x in a blink of an eye.
So while executing the script it accepts the commands coming from the script, but only executes the commands after the script has finished
Thanks for the answer.
We really want to stay away as much as possible of G4 as that is a very fickle command.
The loop in the jinja syntax is a nice one, but I would really need a wait or sleep or delay command as well.
Also other things should be happening, while the output is blinking for 30 sec.
What we used to do was execute a bash script, that executes 3 other bash scripts at the same time.(one of them the 30 sec blinking). This worked very well until we made some upgrades last week (one of them was gcode system commands). And now it waits until all 3 bash scripts are done and then executes all commands in those bash scripts at the same time.
So that will be the hickup for us.
Is there any way to make it run asynchronous.
We tried adding & after the command, but that did not help.
Did the previous version run asynchronous?
Neither version ran async. The previous version was executing commands during the queue phase instead of at the time of sending which resulted in some out of order issues.
Either way I would expect issues with the way you are attempting to implement this.
We tried the ampersand, and it does not work inside of octoprint. (since the update ?)
The ENC command is for the enclosure plugin, to set an output like a gpio pin or a combination of pins.
Any thoughts on a good way to implement ?
@OutsourcedGuru : that is the way that we are doing it, but somehow octoprint still waits until all scripts are finished.
We (I) do have it in the home/pi/.octoprint/scripts folder. Does that matter?
If it's somewhere (usual) within the pi user's space then it would at least be findable and have the appropriate file ownership. You might want to include the content of everything you're discussing.
