Timelapse file location
I used the ocotprint_deploy script and all is working fine except when the timelapse is rendering I can't find them. The folder pointed to by (/usr/bin/ffmpeg) exists, but alas no files.
I haven't been able to resolve on my own.
octoprint-systeminfo-20251027150232 (1).zip (22.3 KB)
I think the path will be based on your printer name you used when setting up with deploy. That path would be somewhere in the home directory, under a hidden folder followed by /timelapse. If you SSH to the pi and run ls -la ./ it should give you all the folders/files including hidden ones. Would be something like...
/home/<username>/.<printer_name>/timelapse
That worked, Thanks!!! now just need to transfer over.
Mel
