Just recently I've been having problems connecting to my printer. It tries to connect but then goes offline with a timeout error.
Tried changing the serial port and baudrate, but with no success. Restarted OctoPrint in safe mode but was still not able to connect. Checked the serial.log and octoprint.log files and did see an uncaught exception in the octoprint.log file (see below). Not sure what it means or how to fix it.
OctoPrint version: 1.3.8
OctoPi version: 0.15.0PE
Printer: Prusa i3 MK3
Printer Firmware: 3.1.2-231
Pi: Raspberry Pi Zero W
Camera: Raspberry Pi Camera Module v2
serial.log (safe mode):
2018-05-28 00:31:55,930 - Connecting to: /dev/ttyAMA0
2018-05-28 00:31:55,958 - Changing monitoring state from "Offline" to "Opening serial port"
2018-05-28 00:31:55,994 - Connected to: Serial<id=0xad35c870, open=True>(port='/dev/ttyAMA0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=10.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2018-05-28 00:31:55,996 - Changing monitoring state from "Opening serial port" to "Connecting"
2018-05-28 00:31:56,026 - Send: N0 M110 N0*125
2018-05-28 00:32:26,074 - There was a timeout while trying to connect to the printer
2018-05-28 00:32:26,119 - Changing monitoring state from "Connecting" to "Offline"
2018-05-28 00:32:26,151 - Connection closed, closing down monitor
octoprint.log (safe mode):
2018-05-28 00:29:26,975 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-05-28 00:29:27,067 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-05-28 00:29:28,180 - octoprint.server - INFO - Shutting down intermediary server...
2018-05-28 00:29:28,411 - octoprint.server - INFO - Intermediary server shut down
2018-05-28 00:29:28,418 - octoprint.events - INFO - Processing startup event, this is our first event
2018-05-28 00:29:28,422 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2018-05-28 00:29:28,438 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-05-28 00:29:28,505 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-05-28 00:29:28,517 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-05-28 00:29:30,403 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-05-28 00:29:30,476 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-05-28 00:29:30,545 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-05-28 00:29:30,622 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "PrusaPrint 😉" for _http._tcp
2018-05-28 00:29:30,747 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "PrusaPrint 😉" for _octoprint._tcp
2018-05-28 00:29:30,804 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance "PrusaPrint 😉" for SSDP
2018-05-28 00:29:30,809 - octoprint.server - INFO - Listening on http://127.0.0.1:5000
2018-05-28 00:29:30,830 - octoprint.server - INFO - Server started successfully in safe mode as requested from config, removing flag
2018-05-28 00:29:32,725 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-05-28 00:29:33,988 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-05-28 00:29:34,539 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http://octopi-prusa-mk3/'}
2018-05-28 00:29:38,936 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-05-28 00:29:47,443 - tornado.application - ERROR - Uncaught exception in /sockjs/026/edckw2uz/websocket
File "/home/pi/oprint/local/lib/python2.7/site-packages/tornado/websocket.py", line 369, in _run_callback
callback(*args, **kwargs)
File "/home/pi/oprint/local/lib/python2.7/site-packages/sockjs/tornado/transports/websocket.py", line 32, in open
self.stream.socket.setsockopt(socket.SOL_TCP, socket.TCP_NODELAY, 1)
AttributeError: 'NoneType' object has no attribute 'setsockopt'
2018-05-28 00:29:47,778 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.164
2018-05-28 00:30:00,660 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
2018-05-28 00:30:53,012 - octoprint.server.preemptive_cache - INFO - ... done in 78.47s
2018-05-28 00:31:01,340 - octoprint.server.util.sockjs - INFO - Client connection closed: ::ffff:192.168.1.164
2018-05-28 00:31:02,646 - octoprint.server.util.sockjs - INFO - New connection from client: ::ffff:192.168.1.164
2018-05-28 00:31:55,965 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-05-28 00:31:55,998 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-05-28 00:31:56,021 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-05-28 00:32:26,122 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Offline"
Any help you can provide would be appreciated. Thanks!
Thank you Gina!
