I get the following message
X/Y
Z
0.1 1 10 100
Feed rate modifier:
% Set
Tool (E)
mm
ExtrudeRetract
Flow rate modifier:
% Set
General
Motors offFan onFan off
OctoPrint 1.5.2
Python 2.7.16
OctoPi 0.17.0
[ About](javascript:void(0))
[ System](javascript:void(0))
Invalid tool reported
Your printer reported tool T0 as invalid, reverting back to T0
Suppressed command
The command T0 was not sent to the printer:
Not queuing T0, that tool doesn't exist according to the printer profile or was reported as invalid by the firmware. Make sure your printer profile is set up correctly.
Checked my printer profile, checked the forums
no, it didn't
Complete Logs
OctoPrint version, OctoPi version, printer, firmware
the latest version of Octoprint
