When I print something, the printer randomly stops after a few Hours. (Sometimes earlier, sometimes later) The Error I see on the Web GUI is: Too many consecutive timeouts, printer still connected and alive?
I changed the USB-Cable (I had a 90Β° bent cable before, I changed that to a cable I used for different stuff (mostly to upload stuff to ESP32s), it always worked), I unplugged my camera and the LEDs I had connected, I ran OctoPrint in safe Mode, I lifted the USB-Cable away from the metal shelf with an empty filament Spool. I plugged my Printer directly into Power (normally I have it connected to a Shelly, so I can turn it off automatically, when the Print finishes), I uninstalled some plugins and ran in safe mode.
Yes, I tried running in safe mode.
No, I tested again, and the Print was cancelled after a few hours.
octoprint-systeminfo-20240615085303.zip (1.3 MB)
I updated Octoprint to the newest Version (before running in safe mode), Octopi Version 1.0.0, running on Raspberry Pi 4 Model B Rev 1.5, Ender 3 V2 Neo (stock firmware), I use mostly Safari as a Browser, but I use the Cura Plugin to print with Octoprint, My Operating Systems are: macOS, iPadOS and Windows (I use Octoprint everywhere, but i usually print from my Mac), I used a Raspberry Pi camera, I had a WS2812B light-Strip connected (I will not connect this in the future anymore, because I want to control the LED-Strip through Home assistant), I had the display of the Printer disconnected, but I read, that the Display-Cable could cause Problems, so I plugged it back in to the Display of the Printer, The Raspberry Pi is connected via a 5-meter long Ethernet-Cable to a Wi-Fi Repeater, which connects to my Wi-Fi (my Wi-Fi is too weak in my basement, where my Printer is) I use an S/FTP-Cable at the moment, but I will change that to a U/UTP-Cable when I test the next time, hopefully with some recommendations from you, what I should try else to fix this issue.
serial.log: Microsoft OneDrive (too big for this Forum)
Thanks in advance
PCBUILD3R
