I am getting failed prints due to this error
Updated Printer Firmware to TH3D 2.6 flashed via octoprint.
Changed usb cable 3 times and purchased a new shielded one from Amazon basics
Also put tape on 5v pin on USB cable, my cable does not have a ferrite core, i might try purchasing some clip on ones from Amazon
Not yet
Not sure yet
It tells me my system info log is too big to upload, its currenly 6MB and your website limit is 4MB. ... no bundle, no support!)
Using the latest version of Octoprint on a raspberry pi 4B
Here is a snippet of where it timed out, it seems to be command - Send: N74050 M105*33
Log snippet:
022-01-09 23:09:06,519 - Recv: T:210.00 /210.00 B:60.00 /60.00 @:97 B@:0
2022-01-09 23:09:07,431 - Recv: ok
2022-01-09 23:09:07,434 - Send: N74048 G1 X182.056 Y149.349 E1710.91711*95
2022-01-09 23:09:07,927 - Recv: ok
2022-01-09 23:09:07,929 - Send: N74049 G1 X182.056 Y137.449 E1711.31291*86
2022-01-09 23:09:08,519 - Recv: T:210.00 /210.00 B:59.99 /60.00 @:97 B@:0
2022-01-09 23:09:17,533 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2022-01-09 23:09:17,536 - Send: N74050 M105*33
2022-01-09 23:09:26,551 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2022-01-09 23:09:26,561 - Send: N74051 M105*32
2022-01-09 23:09:35,563 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2022-01-09 23:09:35,569 - Send: N74052 M105*35
2022-01-09 23:09:44,574 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2022-01-09 23:09:44,580 - Send: N74053 M105*34
2022-01-09 23:09:53,585 - Communication timeout while printing, trying to trigger response from printer. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2022-01-09 23:09:53,590 - Send: N74054 M105*37
2022-01-09 23:10:02,591 - No response from printer after 6 consecutive communication timeouts, considering it dead. Configure long running commands or increase communication timeout if that happens regularly on specific commands or long moves.
2022-01-09 23:10:02,667 - Changing monitoring state from "Printing" to "Offline after error"
2022-01-09 23:10:02,703 - Connection closed, closing down monitor
2022-01-09 23:37:21,402 - Changing monitoring state from "Offline" to "Detecting serial connection"
2022-01-09 23:37:21,451 - Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
2022-01-09 23:37:21,452 - Trying port /dev/ttyUSB0, baudrate 115200
2022-01-09 23:37:21,452 - Connecting to port /dev/ttyUSB0, baudrate 115200
2022-01-09 23:37:21,553 - Handshake attempt #1 with timeout 2.0s
2022-01-09 23:37:21,560 - Connected to: Serial<id=0xa88f4070, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
2022-01-09 23:37:21,561 - Send: N0 M110 N0*125
2022-01-09 23:37:22,431 - Recv: start
2022-01-09 23:37:22,444 - Changing monitoring state from "Detecting serial connection" to "Operational"
2022-01-09 23:37:22,490 - Send: N0 M110 N0*125
2022-01-09 23:37:22,495 - Recv: Marlin TH3D UFW 2.36
2022-01-09 23:37:22,497 - Recv:
