Pas le lecture de la température de la buse. alors que dans les logs et sur l'imprimantes le température est bien affiché (pas de soucis de sonde débranché)
recompilation marlin
OUI
En Safe mode pas de soucis de lecture de température de la buse
Complete Logs
2021-05-11 16:51:48,045 - Send: N1 M115*39
2021-05-11 16:51:48,050 - Recv: FIRMWARE_NAME:Marlin bugfix-2.0.x (Apr 5 2021 19:44:24) SOURCE_CODE_URL:github.com/MarlinFirmware/Marlin PROTOCOL_VERSION:1.0 MACHINE_TYPE:Ender 3 BTT turbo EXTRUDER_COUNT:1 UUID:447584c2-48ba-4872-87a2-851b8c775ac4
2021-05-11 16:51:48,056 -
2021-05-11 16:51:48,056 - ---------------------------------------------------------------------------
2021-05-11 16:51:48,056 - Your printer's firmware is a development build. It might be more unstable
2021-05-11 16:51:48,056 - than a release version and should be updated regularly.
2021-05-11 16:51:48,057 - Learn more at https://faq.octoprint.org/warning-firmware-development
2021-05-11 16:51:48,057 - ---------------------------------------------------------------------------
2021-05-11 16:51:48,063 - Recv: Cap:SERIAL_XON_XOFF:0
2021-05-11 16:51:48,072 - Recv: Cap:BINARY_FILE_TRANSFER:0
2021-05-11 16:51:48,078 - Recv: Cap:EEPROM:1
2021-05-11 16:51:48,082 - Recv: Cap:VOLUMETRIC:1
2021-05-11 16:51:48,088 - Recv: Cap:AUTOREPORT_TEMP:1
2021-05-11 16:51:48,097 - Recv: Cap:PROGRESS:0
2021-05-11 16:51:48,122 - Recv: Cap:PRINT_JOB:1
2021-05-11 16:51:48,146 - Recv: Cap:AUTOLEVEL:1
2021-05-11 16:51:48,187 - Recv: Cap:RUNOUT:0
2021-05-11 16:51:48,222 - Recv: Cap:Z_PROBE:1
2021-05-11 16:51:48,248 - Recv: Cap:LEVELING_DATA:1
2021-05-11 16:51:48,285 - Recv: Cap:BUILD_PERCENT:0
2021-05-11 16:51:48,310 - Recv: Cap:SOFTWARE_POWER:0
2021-05-11 16:51:48,347 - Recv: Cap:TOGGLE_LIGHTS:0
2021-05-11 16:51:48,389 - Recv: Cap:CASE_LIGHT_BRIGHTNESS:0
2021-05-11 16:51:48,423 - Recv: Cap:EMERGENCY_PARSER:0
2021-05-11 16:51:48,433 - Recv: Cap:PROMPT_SUPPORT:0
2021-05-11 16:51:48,441 - Recv: Cap:SDCARD:0
2021-05-11 16:51:48,455 - Recv: Cap:REPEAT:0
2021-05-11 16:51:48,475 - Recv: Cap:SD_WRITE:0
2021-05-11 16:51:48,548 - Recv: Cap:AUTOREPORT_SD_STATUS:0
2021-05-11 16:51:48,577 - Recv: Cap:LONG_FILENAME:0
2021-05-11 16:51:48,639 - Recv: Cap:THERMAL_PROTECTION:1
2021-05-11 16:51:48,669 - Recv: Cap:MOTION_MODES:0
2021-05-11 16:51:48,713 - Recv: Cap:ARCS:1
2021-05-11 16:51:48,735 - Recv: Cap:BABYSTEPPING:0
2021-05-11 16:51:48,773 - Recv: Cap:CHAMBER_TEMPERATURE:0
2021-05-11 16:51:48,803 - Recv: Cap:COOLER_TEMPERATURE:0
2021-05-11 16:51:48,834 - Recv: Cap:MEATPACK:0
2021-05-11 16:51:48,859 - Recv: ok
2021-05-11 16:51:48,889 - Send: M21
2021-05-11 16:51:48,890 - Recv: echo:Unknown command: "M21"
2021-05-11 16:51:48,898 - Recv: ok
2021-05-11 16:51:48,924 - Recv: T:18.00 /0.00 B:21.00 /0.00 @:0 B
OctoPrint : 1.6.1
model: Raspberry Pi 4 Model B Rev 1.2
octopi_version: 0.18.0
Ender 3 pro carte SKR 1,4 turbo, écran TFT 3,5
browser edge windows 10
Windows 10 pro 64 its 20h2**
