Tool Target Temp turns off and print won't start.
I am a complete noob with this and have only really basic knowledge. I use Cura to create my .gcode file, I upload it to OctoPrint and print. I have already printed this file before with success, but now when I click print it flashes the tool temp then it turns off and the print doesn't start.
I have turn off, restarted, rebooted, tried in safe mode, updated, unplugged.
Octoprint 1.3.8, IIIP printer - Since I am a new user, I can't seem to upload a log.
Again, I appreciate the help, My brother set the all up, but is unavailable to help me trouble shoot this.
2018-07-09 14:37:47,026 - tornado.access - WARNING - 401 GET /plugin/softwareupdate/check (127.0.0.1) 82.31ms
2018-07-10 14:19:41,878 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.96
2018-07-10 14:24:28,525 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2018-07-10 14:24:59,785 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/, --user flag needed => no, virtual env => yes
2018-07-10 14:24:59,886 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-07-10 14:25:01,233 - octoprint.plugins.announcements - INFO - Loaded channel _important from in 1.2s
2018-07-10 14:25:03,492 - octoprint.plugins.announcements - INFO - Loaded channel _releases from in 0.96s
2018-07-10 14:25:05,005 - octoprint.plugins.announcements - INFO - Loaded channel _blog from in 0.97s
2018-07-10 14:25:06,605 - octoprint.plugins.announcements - INFO - Loaded channel _plugins from in 1.1s
2018-07-10 14:25:08,329 - octoprint.plugins.announcements - INFO - Loaded channel _octopi from in 0.96s
2018-07-10 14:25:10,015 - octoprint.server.api.system - INFO - Performing command for core:restart: sudo service octoprint restart
2018-07-10 14:25:10,477 - octoprint.server - INFO - Shutting down...
2018-07-10 14:25:10,613 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2018-07-10 14:25:10,646 - octoprint.events - INFO - Event loop shut down
2018-07-10 14:25:10,685 - octoprint.server - INFO - Goodbye!
2018-07-10 14:25:26,714 - octoprint.startup - INFO - ******************************************************************************
2018-07-10 14:25:26,718 - octoprint.startup - INFO - Starting OctoPrint 1.3.6
2018-07-10 14:25:26,721 - octoprint.startup - INFO - ******************************************************************************
2018-07-10 14:25:27,010 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-07-10 14:25:28,210 - octoprint.startup - INFO - Blacklist processing done
2018-07-10 14:25:28,472 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-07-10 14:25:37,411 - octoprint.plugin.core - INFO - Found 8 plugin(s) providing 8 mixin implementations, 4 hook handlers
2018-07-10 14:25:38,150 - octoprint.server - INFO - Intermediary server started
2018-07-10 14:25:38,153 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-07-10 14:25:40,292 - octoprint.plugin.core - INFO - Found 8 plugin(s) providing 8 mixin implementations, 4 hook handlers
2018-07-10 14:25:40,548 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2018-07-10 14:26:03,366 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2018-07-10 14:26:03,690 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2018-07-10 14:26:13,872 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2018-07-10 14:26:23,987 - octoprint.util.pip - INFO - Version of pip is 8.1.1
2018-07-10 14:26:24,003 - octoprint.plugin.core - INFO - Initialized 8 plugin implementation(s)
2018-07-10 14:26:24,052 - octoprint.plugin.core - INFO - 8 plugin(s) registered with the system:
| Announcement Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/announcements
| Core Wizard (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/corewizard
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/cura
| Discovery (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/discovery
| OctoPi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/octopi_support
| Plugin Manager (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/pluginmanager
| Software Update (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/softwareupdate
| Virtual Printer (bundled) = /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins/virtual_printer
2018-07-10 14:26:30,031 - octoprint.environment - INFO - Detected environment is Python 2.7.9 under Linux (linux2). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 389545984
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: unknown
| revision: '0010'
| version: 0.13.0
| python:
| pip: 8.1.1
| version: 2.7.9
| virtualenv: /home/pi/oprint
2018-07-10 14:26:30,076 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-07-10 14:26:30,176 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-07-10 14:26:31,149 - octoprint.server - INFO - Shutting down intermediary server...
2018-07-10 14:26:31,263 - octoprint.server - INFO - Intermediary server shut down
2018-07-10 14:26:31,271 - octoprint.events - INFO - Processing startup event, this is our first event
2018-07-10 14:26:31,276 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2018-07-10 14:26:31,299 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-07-10 14:26:33,213 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from
2018-07-10 14:26:34,335 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 14:26:34,524 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _http._tcp
2018-07-10 14:26:34,870 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _octoprint._tcp
2018-07-10 14:26:34,938 - octoprint.server - INFO - Listening on
2018-07-10 14:26:34,944 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2018-07-10 14:26:35,238 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 14:26:35,281 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-07-10 14:26:35,629 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-07-10 14:26:36,423 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': /'}
2018-07-10 14:26:39,984 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from
2018-07-10 14:26:40,834 - octoprint.plugins.pluginmanager - INFO - Loaded plugin notices data from
2018-07-10 14:26:41,430 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 14:26:41,900 - octoprint.util.comm - INFO - Printer reports firmware name "Repetier_0.91"
2018-07-10 14:26:41,918 - octoprint.util.comm - INFO - Detected Repetier firmware, enabling relevant features for issue free communication
2018-07-10 14:28:01,889 - octoprint.server.preemptive_cache - INFO - ... done in 85.47s
2018-07-10 14:30:37,332 - tornado.access - WARNING - 401 GET /api/printerprofiles (127.0.0.1) 158.64ms
2018-07-10 14:30:37,494 - tornado.access - WARNING - 401 GET /api/files?recursive=true (127.0.0.1) 124.93ms
2018-07-10 14:30:37,644 - tornado.access - WARNING - 401 GET /api/settings (127.0.0.1) 129.66ms
2018-07-10 14:30:37,766 - tornado.access - WARNING - 401 GET /api/slicing (127.0.0.1) 101.84ms
2018-07-10 14:30:37,879 - tornado.access - WARNING - 401 GET /api/timelapse?unrendered=true (127.0.0.1) 93.69ms
2018-07-10 14:30:37,994 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.96
2018-07-10 14:33:19,278 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 14:35:11,211 - octoprint.server.api.system - INFO - Performing command for core:restart_safe: sudo service octoprint restart
2018-07-10 14:35:13,303 - octoprint.server - INFO - Shutting down...
2018-07-10 14:35:14,150 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2018-07-10 14:35:14,212 - octoprint.events - INFO - Event loop shut down
2018-07-10 14:35:14,299 - octoprint.server - INFO - Goodbye!
2018-07-10 14:35:33,766 - octoprint.startup - INFO - ******************************************************************************
2018-07-10 14:35:33,781 - octoprint.startup - INFO - Starting OctoPrint 1.3.6
2018-07-10 14:35:33,785 - octoprint.startup - INFO - Starting in SAFE MODE. Third party plugins will be disabled!
2018-07-10 14:35:33,788 - octoprint.startup - INFO - ******************************************************************************
2018-07-10 14:35:33,995 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-07-10 14:35:34,013 - octoprint.startup - INFO - Blacklist processing done
2018-07-10 14:35:34,300 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-07-10 14:35:44,835 - octoprint.plugin.core - INFO - Found 8 plugin(s) providing 8 mixin implementations, 4 hook handlers
2018-07-10 14:35:45,726 - octoprint.server - INFO - Intermediary server started
2018-07-10 14:35:45,729 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/OctoPrint-1.3.6-py2.7.egg/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-07-10 14:35:48,350 - octoprint.plugin.core - INFO - Found 8 plugin(s) providing 8 mixin implementations, 4 hook handlers
2018-07-10 14:35:48,652 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2018-07-10 14:36:15,058 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2018-07-10 14:36:15,448 - octoprint.plugins.softwareupdate - INFO - Loaded version cache from disk
2018-07-10 14:36:27,593 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2018-07-10 14:36:39,673 - octoprint.util.pip - INFO - Version of pip is 8.1.1
2018-07-10 14:36:39,691 - octoprint.plugin.core - INFO - Initialized 8 plugin implementation(s)
2018-07-10 14:36:39,740 - octoprint.plugin.core - INFO - 8 plugin(s) registered with the system:
2018-07-10 14:36:46,845 - octoprint.environment - INFO - Detected environment is Python 2.7.9 under Linux (linux2). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 389545984
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: unknown
| revision: '0010'
| version: 0.13.0
| python:
| pip: 8.1.1
| version: 2.7.9
2018-07-10 14:36:46,891 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-07-10 14:36:47,027 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-07-10 14:36:48,167 - octoprint.server - INFO - Shutting down intermediary server...
2018-07-10 14:36:48,537 - octoprint.server - INFO - Intermediary server shut down
2018-07-10 14:36:48,545 - octoprint.events - INFO - Processing startup event, this is our first event
2018-07-10 14:36:48,551 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2018-07-10 14:36:48,571 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-07-10 14:36:48,700 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-07-10 14:36:50,702 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-07-10 14:36:51,802 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 14:36:51,971 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _http._tcp
2018-07-10 14:36:52,181 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _octoprint._tcp
2018-07-10 14:36:52,215 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2018-07-10 14:36:52,263 - octoprint.server - INFO - Listening on
2018-07-10 14:36:52,269 - octoprint.server - INFO - Server started successfully in safe mode as requested from config, removing flag
2018-07-10 14:36:52,387 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-07-10 14:36:55,607 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-07-10 14:36:56,535 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http:///'}
2018-07-10 14:36:58,063 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-07-10 14:37:08,243 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.96
2018-07-10 14:38:19,866 - octoprint.server.preemptive_cache - INFO - ... done in 83.33s
2018-07-10 15:06:11,558 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.1.96
2018-07-10 15:06:14,716 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.96
2018-07-10 15:07:15,895 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 15:07:16,833 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 15:07:23,524 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 15:07:23,622 - octoprint.util.comm - INFO - Printer reports firmware name "Repetier_0.91"
2018-07-10 15:07:23,627 - octoprint.util.comm - INFO - Detected Repetier firmware, enabling relevant features for issue free communication
2018-07-10 15:07:42,890 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 15:26:38,507 - octoprint.plugins.softwareupdate - INFO - Starting update of octoprint to 1.3.8...
2018-07-10 15:26:56,202 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2018-07-10 15:27:47,409 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/, --user flag needed => no, virtual env => yes
2018-07-10 15:33:06,597 - octoprint.plugins.softwareupdate - INFO - Update of octoprint to 1.3.8 successful!
2018-07-10 15:33:07,451 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-07-10 15:33:07,463 - octoprint.plugins.softwareupdate - INFO - Restarting...
2018-07-10 15:33:08,153 - octoprint.server - INFO - Shutting down...
2018-07-10 15:33:08,288 - octoprint.events - INFO - Processing shutdown event, this will be our last event
2018-07-10 15:33:08,324 - octoprint.events - INFO - Event loop shut down
2018-07-10 15:33:08,404 - octoprint.server - INFO - Goodbye!
2018-07-10 15:33:28,268 - octoprint.startup - INFO - ******************************************************************************
2018-07-10 15:33:28,272 - octoprint.startup - INFO - Starting OctoPrint 1.3.8
2018-07-10 15:33:28,276 - octoprint.startup - INFO - ******************************************************************************
2018-07-10 15:33:28,469 - octoprint.startup - INFO - We don't appear to be online, not fetching plugin blacklist
2018-07-10 15:33:28,507 - octoprint.util.connectivity_checker - INFO - Connectivity changed from offline to online
2018-07-10 15:33:28,763 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-07-10 15:33:40,912 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 4 hook handlers
2018-07-10 15:33:41,591 - octoprint.server.heartbeat - INFO - Starting server heartbeat, 900.0s interval
2018-07-10 15:33:41,798 - octoprint.server - INFO - Intermediary server started
2018-07-10 15:33:41,802 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins, /home/pi/.octoprint/plugins and installed plugin packages...
2018-07-10 15:33:44,462 - octoprint.plugin.core - INFO - Found 10 plugin(s) providing 10 mixin implementations, 4 hook handlers
2018-07-10 15:33:44,777 - octoprint.filemanager.storage - INFO - Initializing the file metadata for /home/pi/.octoprint/uploads...
2018-07-10 15:34:12,628 - octoprint.filemanager.storage - INFO - ... file metadata for /home/pi/.octoprint/uploads initialized successfully.
2018-07-10 15:34:12,909 - octoprint.plugins.softwareupdate - INFO - Version cache was created for another version of OctoPrint, not using it
2018-07-10 15:34:25,011 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2018-07-10 15:34:36,953 - octoprint.util.pip - INFO - Version of pip is 8.1.1
2018-07-10 15:34:36,959 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages (writable -> yes), --user flag needed -> no, virtual env -> yes
2018-07-10 15:34:36,964 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-07-10 15:34:36,979 - octoprint.plugin.core - INFO - Initialized 10 plugin implementation(s)
2018-07-10 15:34:37,056 - octoprint.plugin.core - INFO - 10 plugin(s) registered with the system:
| CuraEngine (<= 15.04) (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/cura
| OctoPi Support Plugin (bundled) = /home/pi/oprint/lib/python2.7/site-packages/octoprint/plugins/octopi_support
2018-07-10 15:34:37,178 - octoprint.environment - INFO - Detected environment is Python 2.7.9 under Linux (linux2). Details:
| hardware:
| cores: 1
| freq: 700.0
| ram: 389545984
| os:
| platform: linux2
| plugins:
| octopi_support:
| model: unknown
| revision: '0010'
| version: 0.13.0
| python:
| pip: 8.1.1
| version: 2.7.9
2018-07-10 15:34:37,226 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/webassets...
2018-07-10 15:34:37,354 - octoprint.server - INFO - Reset webasset folder /home/pi/.octoprint/generated/.webassets-cache...
2018-07-10 15:34:38,629 - octoprint.server - INFO - Shutting down intermediary server...
2018-07-10 15:34:38,954 - octoprint.server - INFO - Intermediary server shut down
2018-07-10 15:34:38,964 - octoprint.events - INFO - Processing startup event, this is our first event
2018-07-10 15:34:38,971 - octoprint.events - INFO - Adding 1 events to queue that were held back before startup event
2018-07-10 15:34:39,001 - octoprint.filemanager - INFO - Adding backlog items from all storage types to analysis queue...
2018-07-10 15:34:39,151 - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-07-10 15:34:41,721 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-07-10 15:34:43,524 - octoprint.util.comm - INFO - Changing monitoring state from "Offline" to "Opening serial port"
2018-07-10 15:34:43,614 - octoprint.util.comm - INFO - Changing monitoring state from "Opening serial port" to "Connecting"
2018-07-10 15:34:43,745 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 15:34:44,151 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _http._tcp
2018-07-10 15:34:44,163 - octoprint.filemanager - INFO - Added 0 items from storage type "local" to analysis queue
2018-07-10 15:34:44,337 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 15:34:44,413 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for _octoprint._tcp
2018-07-10 15:34:44,511 - octoprint.plugins.discovery - INFO - Registered OctoPrint instance on octopi for SSDP
2018-07-10 15:34:44,538 - octoprint.server - INFO - Listening on http:// - octoprint.plugins.pluginmanager - INFO - Loaded plugin repository data from disk, was still valid
2018-07-10 15:34:46,532 - octoprint.server.preemptive_cache - INFO - Preemptively caching / (ui _default) for {'query_string': 'l10n=en', 'path': '/', 'base_url': 'http:///'}
2018-07-10 15:34:49,185 - octoprint.plugins.pluginmanager - INFO - Loaded notice data from disk, was still valid
2018-07-10 15:34:50,856 - octoprint.util.comm - INFO - Changing monitoring state from "Connecting" to "Operational"
2018-07-10 15:34:50,977 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 15:34:51,293 - octoprint.util.comm - INFO - Printer reports firmware name "Repetier_0.91"
2018-07-10 15:34:51,343 - octoprint.util.comm - INFO - Detected Repetier firmware, enabling relevant features for issue free communication
2018-07-10 15:35:04,081 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.96
2018-07-10 15:35:23,869 - octoprint.util.pip - INFO - Using "/home/pi/oprint/bin/python -m pip" as command to invoke pip
2018-07-10 15:37:02,441 - octoprint.util.pip - INFO - pip installs to /home/pi/oprint/lib/python2.7/site-packages/ (writable -> yes), --user flag needed -> no, virtual env -> yes
2018-07-10 15:37:02,471 - octoprint.util.pip - INFO - ==> pip ok -> yes
2018-07-10 15:37:02,792 - octoprint.plugins.softwareupdate - INFO - Saved version cache to disk
2018-07-10 15:37:45,221 - octoprint.server.preemptive_cache - INFO - ... done in 178.67s
2018-07-10 15:42:25,338 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.1.96
2018-07-10 15:42:27,178 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.96
2018-07-10 15:48:41,611 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-10 15:51:04,224 - octoprint.util.comm - INFO - Changing monitoring state from "Operational" to "Printing"
2018-07-10 15:51:04,295 - octoprint.util.comm - INFO - M110 detected, setting current line number to 0
2018-07-10 15:51:36,122 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:52:07,902 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:52:39,592 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:53:11,375 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:53:43,153 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:54:14,938 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:54:46,632 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:55:18,412 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:55:50,194 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:56:22,025 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:56:53,681 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:57:25,478 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:57:57,242 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:58:29,040 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:59:00,711 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:59:32,503 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 15:59:49,988 - octoprint.server.util.sockjs - INFO - Client connection closed: 192.168.1.96
2018-07-10 15:59:53,945 - octoprint.server.util.sockjs - INFO - New connection from client: 192.168.1.96
2018-07-10 16:00:04,282 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:00:36,062 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:01:07,761 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:01:39,542 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:02:11,314 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:02:43,102 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:03:14,810 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:03:41,617 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2018-07-10 16:03:46,580 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:04:18,362 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:04:50,135 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:05:21,841 - octoprint.util.comm - INFO - Communication timeout while printing, trying to trigger response from printer.
2018-07-10 16:05:30,399 - octoprint.util.comm - INFO - Changing monitoring state from "Printing" to "Cancelling"
