Generic Webcam for Pi with dual IR
I am a bit of a newbie to the Linux world, so please bear with me if my post is not very technical. I purchased the above webcam for my Pi. The Webcam works great with the default installation of Octopi. But I have a 3.5 LCD touch display. I wanted to install Octodash and thus needed to install the touch display drivers for the screen. But as soon as I install the display drivers it disables the webcam.
I have found that it is for sure that the installation of the drivers that break the webcam stream in octopi as it works as soon as I revert to a fresh installation. so I know that the cam is working.
the URL for on the webcam config is "/webcam/?action=stream"
I have tried to update installation and have done a lot of reading online, but nothing that I read actually helped me solve this.
here is the Output from the webcamd.log. Seems (at least the way I understand it) like it is working properly.
cfg_file: /boot/octopi.txt
camera: auto
usb options: -r 640x480 -f 10
raspi options: -fps 10
Explicitly USB device:
Found video devices:
/dev/video0
/dev/video10
/dev/video11
/dev/video12
/dev/video13
/dev/video14
/dev/video15
/dev/video16
/dev/video18
raspi
config file='/boot/octopi.txt':USB device was not set in options, start MJPG-streamer with the first found video device: /dev/video0
<13>Dec 2 23:56:30 root: Starting USB webcam
Running ./mjpg_streamer -o output_http.so -w ./www-octopi -n --listen 127.0.0.1 -i input_uvc.so -r 640x480 -f 10 -d /dev/video0
Goodbye...
i: Frames Per Second.: 10
i: Format............: JPEG
o: HTTP Listen Address..: 127.0.0.1
Starting up webcamDaemon...
Octoprint 1.7.3
Python 3.7.7
Octopi 0.18.0
