TouchUI Octopi Refuse to Connect on TFT. Site not Reachable
Raspberry Pi 4B installed Octoprint > Touch UI on a 7' HDMI Display powered by one of the USB outs on the PI.
Display seems to be functioning however Whenever I load TouchUI on it, I keep getting a site not reachable. Cant connect in the chromium browser.
Have it housed in a GEEKPI Mini PC enclosure thats plastic, with a fan and a small OLED Screen.
I have another raspberry Pi I loaded Octopi and TouchUI on 3 years ago and works flawlessly. It's on a 3.5' TFT and plugged in via the pins.
My seperate computer can ping it, I can get access to it by logging into the desktop. I can access SSH on Putty. It just wont populate on the TFT
I can also use a keyboard and navigate to the google homepage fine and manually type in the .local to get to octoprint. Doesn't directly go there or auto login
Tried Reflashing it, using Raspberry Imager for 1.10.2 both versions currently available on the imager.
Tried that bypass "security" line I found on this forum, Did not work. Disconnected everything drawing power and doesn't work
Im not a script/coding expert so theres not much troubleshooting I can attempt on my own outside whats available on the internet.
No, I dont know how to do that
N/A
Network issues.
