Webcam Stream Not showing
I been using Octoprint ((raspberry Pi 4.0)) for a while now, and been using a simple webcam. ((Model: W8A 8MP)). Image is okay for just using a cam that was laying around. I wanted to upgrade so I got the TPLink KC411S. I can get the image to show on the phone (Ios) I log into Octoprint and click on control. It says I need to click on settings / webcam / so on so forth. I click on the Stream link, and i get the Webcam Server is down. So off to Putty into it. Please help if you can
this is my first post so don't be to mean at my stupidity. hehe
lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 004: ID 0c45:6366 Microdia
Bus 001 Device 003: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
Bus 001 Device 002: ID 2109:3431 VIA Labs, Inc. Hub
Microdia is the old webcam.
QinHeng Looks to be the Ender-3
The rest unsure. ((only the 2 webcams are plugged in USB. And I removed the old webcam, and saw that Microdia was not there))
The TPLink KC114s is not listed.
lsusb
So nano /boot/octopi.txt
took the # off the camera="usb"
took the # off the camera_usb_options="-r 640x480 -f 10 -y" (added the -y)
rebooted, and did lsusb and nothing changed.
So nano /var/log/webcam.log
I see the word Error, and know that's bad.. but no clue what that means. It's been a minuet or 3 since I've used Linux, and still wasn't that good at it.
Nothing changed in Safemode
Nope all the same
