I initially get the error Travel Area exceeds print volume. However If I go into config -> printer profiles -> config -> print bed and volume. Things are correct. Saving as-is. I can then print without issue and no errors. I'm certain this a simple config issue. can print with issue, just get that error every gcode i upload.
Travel exceeds print volume in depth:
Travel Area (0.00, 0.00, 0.00) x 142.29, 293.17, 10.55)
Objects Box: (0.10,2.0,0.00) x(142.29, 200.00, 10.05)
Print volume (0.00,0.00,0.00) x(220.00, 220.00, 250.00)
I notice the travel area is 293.17 for Y, Is Cura embedding that in the file. Cura has the correct bed size.
I can resolve it by going into settings. However the settings are correct.
Have you tried running in safe mode
no
don't know
You can download this in OctoPrint's System Information dialog ... no bundle, no support! )
OctoPrint 1.93
Fedora 39
AnyCubic Kobra2 FW: Marlin (build date 20220725).
Browser FIrefox 100.0
That's really odd
There shouldn't be a reason why y needs to travel to 293 and I'm pretty sure your printer isn't capable of that
mind sharing the gcode?
just zip it and upload it
Cura profiles were messed up and causing this error. Check your start gcode for this line mentioned in this issue post.
opened 09:57PM - 19 Jun 23 UTC
closed 10:29AM - 30 Aug 23 UTC
triage
### The problem
Load a g code file with a move to x0.1 and you get an error 'oc⦠toprint travel area exceeds print volume' even though the g code does not exceed the travel area.
Settings > Printer XYZ is correct at 220, 220, 250 for my Ender 3.
Check off custom settings and don't change anything and the warning stops.
### Did the issue persist even in safe mode?
I cannot test this issue in safe mode (state why below)
### If you could not test in safe mode, please state why
New not know how
### Version of OctoPrint
lower left corner of the web interface is blank
### Operating system running OctoPrint
Debian 12
### Printer model & used firmware incl. version
Ender 3
### Browser and version of browser, operating system running browser
Firefox 102.11.0esr (64-bit)
### Checklist of files to include below
- [X] Systeminfo Bundle (always include!)
- [ ] Contents of the JavaScript browser console (always include in cases of issues with the user interface)
- [ ] Screenshots and/or videos showing the problem (always include in case of issues with the user interface)
- [ ] GCODE file with which to reproduce (always include in case of issues with GCODE analysis or printing behaviour)
### Additional information & file uploads
unable to upload .gcode file
[octoprint-systeminfo-20230619165613.zip](https://github.com/OctoPrint/OctoPrint/files/11793452/octoprint-systeminfo-20230619165613.zip)
Actually I found the answer. It's clearly referenced in the following post
triage
### The problem
New not know how
Debian 12
Ender 3
In short the default Anycubic Kobra(s) end gcode has a Y setting commented out. You need to remove the semi-colon.
It fixed my issue (at least so far).
system
Closed
April 15, 2024, 3:49am
5
