New Tronxy X5S was connecting but after update to 1.3.12 it will not connect. Error: State: Offline (Error: Printer keeps requesting line 4 again and again, communication stuck)
All updated including Python. I tried three different SD cards in my Raspberry Pi 3B which is controlled from a Windows 10 machine. My Anet A8 updated on the same day, in the same way, works properly but has no camera. Ordered new camera to see if that's it.
I mean change the value in the marlin config if necesarry
It looks like a similar problem on Anycubic printers. The solution for those would be this
But I'm not sure if it's the same issue here.
We should wait for @foosel or any other person with a better idea
Please provide the serial.log - she will probably need it
The only way my X5S will connect is to set both the port and baud rate to "Auto". And there is a setting I ran across a while back to increase the wait time. This made connections reliably since then. Sorry don't remember the exact setting and can't trace it down right now as my pi decided to go on vacation for some reason. Oh and the the baud rate worked out to 115200.
Now trying to flash the board which is based on an STM32 chip. I have installed STM32FLASH but after an hour of trolling about with putty I am unable to find the path to this which is needed in the plugin setup. Any ideas as to where it is hiding ?
Still no joy. I simply cannot print with Octopi. Ihave some progress in that I can see the camera and the controls work through the keyboard of the remote computer. Furthermore I am occasionally able to launch a print and the machine will come to life indicating a temperature rise on the graph but no rise in the actual temperature of the machine. The system then hangs. So some commands are getting through but not others. I have had this machine half a year now and have yet to print anything.
If the graph indicates an increasing temperature, then it's your firmware which is returning that information. Visit the Terminal tab, toggle off some of the information but leave the temperature-related lines in the log. Watch what's happening. Each line returned from the firmware is interpreted by OctoPrint as reality.
Copy/paste one of those lines here, having just set the temperature in the Control tab. (Some of the odd firmwares provided by manufacturers deviate from the expected style of reporting.)
Thanks for the reply. The firmware is not actually replying at all. The temperature graph goes straight to 60 for the bed and 200 for the filament and nothing else happens.
The fans come on as if printing has started but nothing else. This printer is the newest X5ST-400 and it's using an STM32F103 chip.
