Basically what the title says. I'm trying to enable guest access and found that in order to enable users to view the system without logging in the plugin ForceLogin needs to be disabled but it doesn't show up in the Plugin Manager.
I tried installing the plugin manually from
https://github.com/OctoPrint/OctoPrint-ForceLogin/archive/master.zip then disabling the plugin but this produced no changes, users still are confronted with the login screen
octoprint.log:
2020-03-06 19:22:35,003 - octoprint.server.heartbeat - INFO - Server heartbeat <3
2020-03-06 19:22:35,007 - octoprint.server - INFO - --- Log roll over detected ---------------------------------------------------
2020-03-06 19:22:35,008 - octoprint.server - INFO - OctoPrint 1.3.12
2020-03-06 19:22:35,016 - octoprint.plugin.core - INFO - 20 plugin(s) registered with the system:
| AstroPrint (1.4.1) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_astroprint
| Filament Manager (0.5.3) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_filamentmanager
| Octolapse (0.3.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_octolapse
| The Spaghetti Detective (1.1.4) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_thespaghettidetective
| Themeify (1.2.0) = /home/pi/oprint/local/lib/python2.7/site-packages/octoprint_themeify
2020-03-06 19:22:35,042 - octoprint.environment - INFO - Detected environment is Python 2.7.13 under Linux (linux2). Details:
| hardware:
| cores: 4
| freq: 1200.0
| ram: 918188032
| os:
| platform: linux2
| plugins:
| pi_support:
| octopi_version: 0.16.0
| python:
| pip: 19.0.1
| version: 2.7.13
| virtualenv: /home/pi/oprint
OctoPrint version Version 1.4.0
OctoPi version: 0.16.0, running on Raspberry Pi 3 Model B Rev 1.2
Browser: Chrome Version 80.0.3987.122
Operating System: Windows 10 Pro
