Inland RaspberryPi Camera v1.3
Can't access my camera via webcam or strraming
sudo apt update && sudo apt upgrade
edited /boot/firmware/config.txt by adding dtoverlay=ov5647
vcgencmd get_camera results supported=1 detected=0, libcamera interfaces=1
rpicam-hello
[92:55:02.108420039] [18039] INFO Camera camera_manager.cpp:330 libcamera v0.5.2+99-bfd68f78
[92:55:02.139978068] [18042] INFO IPAProxy ipa_proxy.cpp:180 Using tuning file /usr/share/libcamera/ipa/rpi/vc4/ov5647.json
[92:55:02.146600630] [18042] INFO Camera camera_manager.cpp:220 Adding camera '/base/soc/i2c0mux/i2c@1/ov5647@36' for pipeline handler rpi/vc4
[92:55:02.146678407] [18042] INFO RPI vc4.cpp:440 Registered camera /base/soc/i2c0mux/i2c@1/ov5647@36 to Unicam device /dev/media4 and ISP device /dev/media1
[92:55:02.146718999] [18042] INFO RPI pipeline_base.cpp:1107 Using configuration file '/usr/share/libcamera/pipeline/rpi/vc4/rpi_apps.yaml'
Made DRM preview window
Preview window unavailable
Mode selection for 1296:972:12:P
SGBRG10_CSI2P,640x480/0 - Score: 3296
SGBRG10_CSI2P,1296x972/0 - Score: 1000
SGBRG10_CSI2P,1920x1080/0 - Score: 1349.67
SGBRG10_CSI2P,2592x1944/0 - Score: 1567
Stream configuration adjusted
[92:55:02.149479207] [18039] INFO Camera camera.cpp:1215 configuring streams: (0) 1296x972-YUV420/sYCC (1) 1296x972-SGBRG10_CSI2P/RAW
[92:55:02.149693999] [18042] ERROR V4L2 v4l2_videodevice.cpp:1096 /dev/video0[10:cap]: Unable to set format: Device or resource busy
ERROR: *** failed to configure streams ***.
browser.user_agent: Mozilla/5.0 (X11; Linux x86_64; rv:147.0) Gecko/20100101 Firefox/147.0
connectivity.connection_check: 9.9.9.9:53
connectivity.enabled: True
connectivity.online: True
env.hardware.cores: 4
env.hardware.freq: 1800.0
env.hardware.ram: 3967201280
env.os.bits: 32
env.os.id: linux
env.os.platform: Linux-6.12.62+rpt-rpi-v7l-armv7l-with-glibc2.36
env.plugins.pi_support.model: Raspberry Pi 4 Model B Rev 1.5
env.plugins.pi_support.octopi_camera_stack: webcamd
env.plugins.pi_support.octopi_version: 1.1.0
env.plugins.pi_support.octopiuptodate_build: 1.1.0-1.11.5-20251201130812
env.plugins.pi_support.octopiuptodate_build_short: 2025.12.01.130812
env.python.pip: 25.0.1
env.python.version: 3.11.2
env.python.virtualenv: True
octoprint.last_safe_mode.date: unknown
octoprint.last_safe_mode.reason: unknown
octoprint.safe_mode: False
octoprint.version: 1.11.6
systeminfo.generated: 2026-01-29T00:55:01Z
systeminfo.generator: zipapi
OctoPrint v1.11.6, OctoPi v1.1.0, Firefox, Linux Mint v22.3
