Trouble getting Octoprint to boot up
Cannot get the Octoprint to load to the http://192.168.0.26/#temp, can't get to load using octoprint.local either. I get this every time: This site can’t be reached
192.168.0.26 took too long to respond.
Just try to keep loading , did a restart of computer
Can't get to that point
N/A
WRITE HEREI have had Octoprint for 3 years, on my Prusa MK3s, with a pie installed. I can't get the logs because it will not come on when clicking my normal Octoprint icon on my tool bar. I just used it about a month ago or less. I have restarted computer, 3d printer, and pie, with no luck. I updated Octoprint and all the add ons last time I was on, and it ran fine. I have ran acreoss this problem before, but just reloaded the page and started up. I am using a Windows 10 machine. Don't know what more I can tell you. Just checked my network IP address, and it says 0.25 instead of 0.26, but that doesn't change anything , and has always connected with the 0.26
This is the error that I come up with:: This site can’t be reached
You've provided no information about your setup here. It is very difficult to suggest anything when we don't even know if you've actually installed OctoPrint or where or how you've installed it.
Please consider adding as much information as possible to your post, because we are not mind readers.
check on your router I bet the IP address has changed for octoprint.
Yep that is what it was, reassigned another ip address. Thanks for the advise. Another thing is I usually have to hit connect several times to get connected. I have hit it about 4 times and did not connect at 11500 baud rate, then changed it to Auto and it connected. Don't know why. Thanks bunches.
