So i have a TRONXY 2 pro and it has some issues communicating with Octoprint i get lots of this
Recv: //callback_pf error
Recv: ok N:705
Send: N706 G1 X138.304 Y130.620 E0.0270*93
Recv: ok duplicate line:705
Send: N707 G1 X138.071 Y130.698 E0.0279*87
Recv: ok N:705
Send: N708 G1 X137.913 Y130.811 E0.0221*88
Recv: Resend:706
Recv: //last:705 curr:707 rcv:N707 G1 X138.071 Y130.698
E0.0279*87
one of the ways around this from users is installing a plugin that Gina had very kindly created (THANKYOU GINA!)
and
when i go into octoprint i try to put the ZIP files into the "browse" section of the plugin library and i get this output.
Installing plugin from uploaded archive...
/home/pi/OctoPrint/venv/bin/python2 -m pip --disable-pip-version-check install /tmp/tmpNFJ0Es.zip --no-cache-dir
Processing /tmp/tmpNFJ0Es.zip
ERROR: Command errored out with exit status 1:
command: /home/pi/OctoPrint/venv/bin/python2 -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-req-build-eNcWgX/setup.py'"'"'; file='"'"'/tmp/pip-req-build-eNcWgX/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-req-build-eNcWgX/pip-egg-info
cwd: /tmp/pip-req-build-eNcWgX/
Complete output (3 lines):
File "", line 1, in
IOError: [Errno 2] No such file or directory: '/tmp/pip-req-build-eNcWgX/setup.py'
ERROR: Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Error!
Could not parse output from pip, see plugin_pluginmanager_console.log for generated output
im not really sure on my installation where the log is located so i can't really show it.
but i'm trying to figure out how to manually install both of those plugins so it will work and hopefully i can get this printer running on Octoprint.
if it's of any help i have this for my plugin locations but i'm not really seeing anything of use in there.
Using pip of "/home/pi/OctoPrint/venv/bin/python2", Version 20.0.2
Installation directory: /home/pi/OctoPrint/venv/lib/python2.7/site-packages ("--user" flag: no)
Virtual environment: yes
any help would be great. thankyou!
