Since today when I turn on my Octopi and try to load the login page for Octoprint this weird text comes up. Yesterday I did not have any troubles.
I didn't change anything on my networking nor my printer/pi.
I am quite new to Octoprint so I dont really know what I could try.
I tried to google my issue but couldn't really find anything.
Edit: I can connect through OctoRemote on Android, but I can't connect my printer
(Error: No more candidates to test, and no working port/baudrate combination detected.)
Restart, reboot, restart in safe mode nothing helped.
Tried different browsers on pc and on my phone.
= wrapperCommit; lodash.prototype.concat = wrapperConcat; lodash.prototype.plant = wrapperPlant; lodash.prototype.reverse = wrapperReverse; lodash.prototype.toString = wrapperToString; lodash.prototype.run = lodash.prototype.toJSON = lodash.prototype.valueOf = lodash.prototype.value = wrapperValue; // Add function aliases to the lodash wrapper. lodash.prototype.collect = lodash.prototype.map; lodash.prototype.head = lodash.prototype.first; lodash.prototype.select = lodash.prototype.filter; lodash.prototype.tail = lodash.prototype.rest; return lodash; } /--------------------------------------------------------------------------/ // Export lodash. var _ = runInContext(); // Some AMD build optimizers like r.js check for condition patterns like the following: if (typeof define == 'function' && typeof define.amd == 'object' && define.amd) { // Expose lodash to the global object when an AMD loader is present to avoid // errors in cases where lodash is loaded by a script tag and not intended // as an AMD module. See http://requirejs.org/docs/errors.html#mismatch for // more details. root._ = _; // Define as an anonymous module so, through path mapping, it can be // referenced as the "underscore" module. define(function() { return _; }); } // Check for exports after define in case a build optimizer adds an exports object. else if (freeExports && freeModule) { // Export for Node.js or RingoJS. if (moduleExports) { (freeModule.exports = ). = ; } // Export for Rhino with CommonJS support. else { freeExports. = ; } } else { // Export for a browser or Rhino. root. = _; } }.call(this));
Running Octoprint version 1.5.3 on Pi 3b+
