Trouble Upgrading from Octoprint 1.3.11 to 1.9.1
When I try to upgrade from octoprint 13.11 to 1.9.1 I get the following error message:
Updating, please wait.
/home/pi/oprint/bin/python2 -m pip --disable-pip-version-check install https://github.com/foosel/OctoPrint/archive/1.9.1.zip --no-cache-dir
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Collecting https://github.com/foosel/OctoPrint/archive/1.9.1.zip
Downloading https://github.com/foosel/OctoPrint/archive/1.9.1.zip (6.3MB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'error'
Complete output from command /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpq3dsDx:
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 207, in <module>
main()
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 197, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py", line 54, in get_requires_for_build_wheel
return hook(config_settings)
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/build_meta.py", line 115, in get_requires_for_build_wheel
return _get_build_requires(config_settings, requirements=['wheel'])
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/build_meta.py", line 101, in _get_build_requires
_run_setup()
File "/home/pi/oprint/local/lib/python2.7/site-packages/setuptools/build_meta.py", line 85, in _run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 237
f"{update.spec}: latest {update.latest}, pypi: https://pypi.org/project/{update.name}/"
SyntaxError: invalid syntax
Command "/home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip/_vendor/pep517/_in_process.py get_requires_for_build_wheel /tmp/tmpq3dsDx" failed with error code 1 in /tmp/pip-req-build-jHVciD
N/A
Yes
No.
Cannot obtain in 1.3.11
This is on a Raspberry pi. Printer is MPSM v2 but I don't think it matters. I've come back to this after a few years and unable to update. I was getting a different error earlier, and another forum post led me to disable the logging plugin. After that, I get the above error message.
Hello @thepiercingarrow !
OctoPrint 1.3.11 runs on python 2.7, OctoPrint 1.9.1 needs python 3.
I recommend to run a backup, and then start with a fresh OctoPi 1.0.0.
