Trouble with ports on local network [SOLVED]
Unresponsive web interface
Different browsers, different operating systems
OctoPrint 1.3.10 running on OctoPi 0.15.1
Hi all,
I have an Octopi connected to an Anet A8 printer.
As I understand it, pointing a browser at it from another computer on the local network should bring up the web interface, allowing me to add files, print, view webcam, control the printer etc.
When I do this sometimes I get the interface, sometimes just an unresponsive page theat looks like I need to log in. Tried this and still unresponsive. When it works, it only does so for a short time then freezes up, refreshing gets me back to the basic octoprint page.
I also have on my home network another couple of Raspberry Pi's
One runs nextcloud (among other things)
Nextcloud uses ports 443 and 80 the same as octoprint.
I think I would like to change the ports octoprint uses to something else to try and avoid a port clash with nextcloud.
How would I manage this, the information I have found is confusing.
Rev
  • The Raspberry Pi which is connected to the Anet A8: we need to know what model that is. A Raspberry Pi Zero W only has a single core and could be the problem if that's the case. A Raspberry Pi 3B would be what I'd recommend since it has four cores.
  • "pointing a browser from another computer": You could be more specific here, as in what kind of computer and what kind of browser?
  • How is this Pi connected to your network (Ethernet cable or wi-fi)? How is your computer connected to your network (same)?
  • "sometimes just an unresponsive page that looks like I need to log in.": A picture is worth a thousand words, as they say. Upon bootup or restarting OctoPrint, it takes a moment for OctoPrint to get going. Until it's completely ready it will display very spartan screens which indicate that it's not ready yet. For a one-core Raspberry, this process takes longer.
Whether or not a second Raspberry Pi is running services on 80/443, this shouldn't matter for the first Raspberry Pi which is serving OctoPrint.
I'm using a Raspberry Pi 3B+ on the printer (new a week ago)
The PC I'm using is a dual boot Windows 10/Linux Mint machine, Ryzen 2400G, 16Gb memory, 500Gb SSD. I don't use windows much.
The browsers I've tried, Windows - Chrome, Firefox, Edge. Linux - Chrome, Firefox, Epiphany (all latest versions)
The Pi3B+ (printer) is connected wireless, SSH enabled and no issues with connectivity. The PC is wired.
I have a Pi2B running kodi wired. A Pi ZeroW running kodi wireless, a Pi3B+ running nextcloud (1Tb USB HDD), transmission, couchpotato, sabnzbd, sickrage, test website. This is also wired. Along with my phone (android) and a rarely used old laptop which access the network.
Fibre broadband with wireless/wired hub.
As for the spartan screen, very good description! that's it perfectly, even after waiting 15 minutes it stays the same. The Pi3B+ on the printer is using an official PSU as I thought power might be an issue.
When it is running the elapsed time clock counts for about 10 seconds the freezes. I have used a few different SD cards and fresh images to eliminate a dodgy card.
Rev
What we know
  • Your PC (Linux) is wired via Ethernet to your network as well as the Pi2B and a Pi3B+ (not related to OctoPi).
  • Your Pi3B+ with OctoPi is wireless as well as a Pi Zero W.
  • Your network router is responsible for moving traffic between the wired side of things and the wireless side of things.
What we don't know
  • We don't know if your Linux install has Bonjour as a name-resolution service. This would be handy for converting a hostname like "octopi.local" into an IP address.
  • We don't know if your router is causing the hiccups in traffic.
  • We don't know if your wifi zone is 2.4Ghz or 5Ghz. The Raspberry Pi 3B+ now supports 2.4Ghz/5Ghz but the Zero W only does 2.4Ghz.
As a troubleshooting step, it would be great to physically connect the 3B+ to Ethernet to see if this works great. If so, then treat this as either a wonky wifi setup (competition with your neighbors?) or perhaps there are things in your house which are reflecting back the wifi signals or blocking them.
Sorry Sir :wink:
afaik "Bonjour" isn't necessary under Linux this is such a "apple-thingie" :thinking:
Thanks for the help, really useful.
The issue is a lost cause, I'll live with it.
Rev
