Want to set static IP and change port on newest raspberry pi with newest python
tried editing ~/.octoprint/config.yaml - with host: and port:
server:
Use this option to define the host to which to bind the server, defaults to "0.0.0.0" (= all
interfaces)
host: 192.168.1.31
Use this option to define the port to which to bind the server, defaults to 5000
port: 7005
If this option is true, OctoPrint will show the First Run wizard and set the setting to
false after that completes
Did running in safe mode solve the problem
why?
huh?
The Raspberry Pi IP address(es) are determined by the operating system and setting a static IP address is an OS function completely independent of OctoPrint.
The port (and IP address) that OctoPrint listens to would be changed in configuration files associated with it, but I'm pretty sure changes to .octoprint/config.yaml are not the way to do that.
As we narrow in on what you are doing and how we can help, please use the </> preformatted text tool when posting text captured from your system. This will prevent the markdown editor from "reformatting" it (YAML formatting is important).
The blue text in the template are links to additional information. In particular, we would really like to have the systeminfo bundle and as much additional information details as possible. The more details you give us, the more help we can provide.
Correct - although there are postings telling you changing the yaml will do it they don't do anything. The older OS was done easily in to Linux files - not no more! I need to change ports and set static ips. Guess I wasted time here because it's an OS issue - sorry. But thanks for showing me what I already believed!
I did not say I changed anything via DNS because that would change nothing but the DNS entry as you well know[?]! I want to set a static IP and port Octoprint listens on like I used to be able to with the older now NON supported Python versions. Why we need to update Python is ridiculous - who is going to hack my raspberry pi and why waste their time! listens on SERIOUSLY!. Surely someone knows how to do this? THANKS?
You espoused a proficiency with Windows DHCP services. Given that, you can get it to set a static IP address and DNS (A Record) or bypass DHCP or set a fixed address on the PI directly.
That solves your Fixed IP issue no matter which version of OctoPi you use.
I already told you how to change the port to something non-standard above. I assume that trivial change is not beyond your capabilities.
Python needs to be upgraded to keep up with the updates. You could simply choose not to use more recent versions of OctoPI and so not worry about Python versions.
