After a longer period I had to update everything. the last one was OctoPrint 1.5.3
The installation ended always with an error message
I just want to continue where I have been already ....
ERROR: Command errored out with exit status 1:
ImportError: cannot import name NullHandler
ERROR: Command errored out with exit status 1: /home/pi/oprint/bin/python2 /home/pi/oprint/local/lib/python2.7/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-6QlDfe/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple --extra-index-url https://www.piwheels.org/simple -- setuptools wheel Cython Check the logs for full command output.
I deinstalled several plugins which have been outdated.
hoiw to start the safe mode for an installation???
Complete Logs
If I input the log the system tells me 'as new user you can only put 5 links'
Ender3 with Raspberry Pi 3 and OctoPrint 1.4
PiCam (which makes a problem as well....
