I am currently trying to upload gcode files to the octoprint local server using the octoprint api and node red. I have managed to POST a very small gcode file, 29 KB but when I try to POST another gcode file, 4 MB in size, I get a response on node red of:
"Error: write EPIPE"
or
"Error: socket hang up
both with
statusCode: "ECONNRESET"
the msg I am posting looks like this and I am POSTing it as a utf-8 string
msg.headers = {
"Content-Type": "multipart/form-data; boundary=----WebKitFormBoundaryDeC2E3iWbTv1PwMC",
"X-Api-Key": "XXXXXXXXXX"
msg.payload = '------WebKitFormBoundaryDeC2E3iWbTv1PwMC\r\n'+
'Content-Disposition: form-data; name="select"\r\n'+
'\r\n'+
'true\r\n'+
'Content-Disposition: form-data; name="print"\r\n'+
'\r\n'+
'false\r\n'+
'Content-Disposition: form-data; name="file"; filename="'+filename+'"\r\n'+
'Content-Type: application/octet-stream
'GCODE'
'------WebKitFormBoundaryDeC2E3iWbTv1PwMC--';
- uploading the file to octoprint using the regular octoprint GUI works fine
- POSTing the file internally works (i.e. to another node in node red).
- I am running node red and octopi on the same raspberry pi 3B+
- I checked the node red maximum HTTP request data volumes and timeouts and made sure they were not the issue - I am wondering if there is some kind of limit on octoprint api upload
- Checked the octoprint.log: shows the file analysis for the small file but nothing for the larger one
- Tried POSTing the file to a temporary location before POSTing it to the Octoprint server from that folder
Octoprint Version: 1.3.10
Octopi Version: 0.16.0
Node Red Flow:
[{"id":"3f7e7ffa.4734","type":"ui_template","z":"d0969e5.ee64a6","group":"bc476fb4.91eae","name":"Upload HTML","order":13,"width":"8","height":"2","format":"<h1>Upload</h1>\n\n<form action=\"/temp\" method=\"POST\" enctype=\"multipart/form-data\">\n <input type=\"file\" name=\"myFile\" />\n <input type=\"submit\" value=\"Submit\">\n</form>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":1380,"y":280,"wires":[[]]},{"id":"ae8c13a7.6bfe1","type":"function","z":"d0969e5.ee64a6","name":"Format the header and payload","func":"msg.headers = {\n \"Content-Type\": \"multipart/form-data; boundary=----WebKitFormBoundaryDeC2E3iWbTv1PwMC\", \n \"X-Api-Key\": \"XXXXXXXXXX\"\n}\n\n\nmsg.payload = '------WebKitFormBoundaryDeC2E3iWbTv1PwMC\\r\\n'+\n'Content-Disposition: form-data; name=\"select\"\\r\\n'+\n'\\r\\n'+\n'true\\r\\n'+\n'------WebKitFormBoundaryDeC2E3iWbTv1PwMC\\r\\n'+\n'Content-Disposition: form-data; name=\"print\"\\r\\n'+\n'\\r\\n'+\n'false\\r\\n'+\n'------WebKitFormBoundaryDeC2E3iWbTv1PwMC\\r\\n'+\n'Content-Disposition: form-data; name=\"file\"; filename=\"'+msg.req.files[0].originalname+'\"\\r\\n'+\n'Content-Type: application/octet-stream\\r\\n'+\n'\\r\\n'+\nmsg.req.files[0].buffer.toString()+'\\r\\n'+'\\r\\n'+\n'------WebKitFormBoundaryDeC2E3iWbTv1PwMC--';\n\n\nreturn msg;","outputs":1,"noerr":0,"x":1610,"y":360,"wires":[["e0a2faa3.61f9c8","af10b7df.746cb8"]]},{"id":"aec424f6.b420f8","type":"http response","z":"d0969e5.ee64a6","name":"","statusCode":"","headers":{},"x":1830,"y":300,"wires":[]},{"id":"c000a6a1.93de68","type":"http in","z":"d0969e5.ee64a6","name":"","url":"/temp","method":"post","upload":true,"swaggerDoc":"","x":1350,"y":360,"wires":[["ae8c13a7.6bfe1","729b8d86.ae6ca4"]]},{"id":"e0a2faa3.61f9c8","type":"debug","z":"d0969e5.ee64a6","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1750,"y":440,"wires":[]},{"id":"729b8d86.ae6ca4","type":"change","z":"d0969e5.ee64a6","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"file uploaded","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":1630,"y":300,"wires":[["aec424f6.b420f8"]]},{"id":"af10b7df.746cb8","type":"http request","z":"d0969e5.ee64a6","name":"","method":"POST","ret":"txt","paytoqs":false,"url":"http://racka/aa/api/files/local","tls":"","proxy":"","authType":"basic","x":2050,"y":360,"wires":[["91ed4e52.bdbd4"]]},{"id":"91ed4e52.bdbd4","type":"debug","z":"d0969e5.ee64a6","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":2230,"y":360,"wires":[]},{"id":"bc476fb4.91eae","type":"ui_group","z":"","name":"AA","tab":"86ac15ae.8d8e88","order":1,"disp":true,"width":"10","collapse":true},{"id":"86ac15ae.8d8e88","type":"ui_tab","z":"","name":"Overview","icon":"dashboard","disabled":false,"hidden":false}]
Any help would be much appreciated
