I cannot run Octopi and cannot solve this error.
tried different versions of octopi, sluguify and regex
Additional information about your setup (OctoPrint version, OctoPi version, printer, firmware, octoprint.log
, serial.log
or output on terminal tab, ...)
I am trying to run it on a OrangePi PC with armbian
pi@orangepipc:~/OctoPrint$ ~/OctoPrint/venv/bin/octoprint serve
^[[3~2018-11-06 16:58:02,491 - octoprint.startup - INFO - ******************************************************************************
2018-11-06 16:58:02,494 - octoprint.startup - INFO - Starting OctoPrint 1.3.9
2018-11-06 16:58:02,496 - octoprint.startup - INFO - ******************************************************************************
2018-11-06 16:58:03,684 - octoprint.plugin.core - INFO - Loading plugins from /home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins, /root/.octoprint/plugins and installed plugin packages...
2018-11-06 16:58:04,443 - octoprint.plugin.core - ERROR - Error loading plugin softwareupdate
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/plugin/core.py", line 847, in _import_plugin
instance = imp.load_module(key, f, filename, description)
File "/home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/softwareupdate/init.py", line 26, in
from octoprint.server.util.flask import restricted_access, with_revalidation_checking, check_etag
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/server/init.py", line 65, in
from octoprint.printer.profile import PrinterProfileManager
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/printer/init.py", line 28, in
from octoprint.filemanager import FileDestinations
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/filemanager/init.py", line 18, in
from .storage import LocalFileStorage
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/filemanager/storage.py", line 27, in
from slugify import Slugify
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/slugify/init.py", line 2, in
from slugify.main import Slugify, UniqueSlugify
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/slugify/main.py", line 68, in
class Slugify(object):
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/slugify/main.py", line 70, in Slugify
upper_to_upper_letters_re = re.compile(UPPER_TO_UPPER_LETTERS_RE, re.VERBOSE | re.VERSION1)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/regex.py", line 345, in compile
return _compile(pattern, flags, kwargs)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/regex.py", line 486, in _compile
parsed = _parse_pattern(source, info)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/_regex_core.py", line 388, in _parse_pattern
branches = [parse_sequence(source, info)]
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/_regex_core.py", line 413, in parse_sequence
element = parse_paren(source, info)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/_regex_core.py", line 823, in parse_paren
subpattern = _parse_pattern(source, info)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/_regex_core.py", line 410, in parse_sequence
sequence.append(parse_escape(source, info, False))
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/_regex_core.py", line 1186, in parse_escape
return parse_property(source, info, ch == "p", in_set)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/_regex_core.py", line 1341, in parse_property
prop = lookup_property(prop_name, name, positive != negate, source)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/_regex_core.py", line 1603, in lookup_property
value = standardise_name(value)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/regex_core.py", line 1593, in standardise_name
return ascii_upper("".join(ch for ch in name if ch not in "- "))
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/_regex_core.py", line 1586, in ascii_upper
return s.translate(upper_trans)
TypeError: character mapping must return integer, None or unicode
2018-11-06 16:58:04,580 - octoprint.plugin.core - ERROR - Error loading plugin logging
File "/home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/logging/init.py", line 10, in
from octoprint.server import NO_CONTENT, admin_permission
2018-11-06 16:58:04,630 - octoprint.plugin.core - ERROR - Error loading plugin printer_safety_check
File "/home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/printer_safety_check/init.py", line 10, in
from octoprint.server import user_permission
2018-11-06 16:58:04,644 - octoprint.plugin.core - WARNING - Plugin "OctoPi Support Plugin" did not pass check
2018-11-06 16:58:04,871 - octoprint.plugin.core - ERROR - Error loading plugin announcements
File "/home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/announcements/init.py", line 23, in
from octoprint.server import admin_permission
2018-11-06 16:58:04,906 - octoprint.plugin.core - ERROR - Error loading plugin action_command_prompt
File "/home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/action_command_prompt/init.py", line 9, in
2018-11-06 16:58:05,001 - octoprint.plugin.core - ERROR - Error loading plugin pluginmanager
File "/home/pi/OctoPrint/venv/lib/python2.7/site-packages/octoprint/plugins/pluginmanager/init.py", line 14, in
2018-11-06 16:58:05,621 - octoprint.plugins.discovery - INFO - pybonjour is not installed, Zeroconf Discovery won't be available
2018-11-06 16:58:05,629 - octoprint.plugin.core - INFO - Found 4 plugin(s) providing 4 mixin implementations, 1 hook handlers
2018-11-06 16:58:05,769 - octoprint.cli.server - ERROR - Uncaught exception
File "/home/pi/OctoPrint/venv/bin/octoprint", line 11, in
sys.exit(main())
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/init.py", line 599, in main
octo(args=args, prog_name="octoprint", auto_envvar_prefix="OCTOPRINT")
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/click/core.py", line 716, in call
return self.main(*args, **kwargs)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/click/core.py", line 696, in main
rv = self.invoke(ctx)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/click/core.py", line 1060, in invoke
return _process_result(sub_ctx.command.invoke(sub_ctx))
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/click/core.py", line 889, in invoke
return ctx.invoke(self.callback, **ctx.params)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/click/core.py", line 534, in invoke
return callback(*args, **kwargs)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/click/decorators.py", line 17, in new_func
return f(get_current_context(), *args, **kwargs)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 188, in serve_command
ignore_blacklist)
File "/home/pi/OctoPrint/venv/local/lib/python2.7/site-packages/octoprint/cli/server.py", line 97, in run_server
from octoprint.server import Server
