We've just upgraded with a fresh install to the latest version of OctoPi, but now get a connection problem when trying to print. OctoPrint is able to connect and monitor temperatures on the printer however.
This is a Monoprice Dual Extruder printer (clone of Replicator 2X) that has previously worked with the GPX plugin on a much older version of OctoPrint.
OctoPrint 1.3.6 running on OctoPi 0.14.0
Changing monitoring state from 'Offline' to 'Error: Connection error, see Terminal tab'
Unexpected error while connecting to serial port: AUTO IOError: 'AUTO port and baudrate not currently supported by GPX' @ comm.py:_openSerial:1931 (hook GPX)
Changing monitoring state from 'Offline' to 'Opening serial port'
Connected to: <GPX.gpxprinter.GpxPrinter instance at 0x6f4e56e8>, starting monitor
Changing monitoring state from 'Opening serial port' to 'Connecting'
Recv: start
Send: N0 M110 N0*125
Recv: Makerbot v7.2
Recv: echo: gcode to x3g translation by GPX
Recv: SD init fail
Recv: T:26 /0 B:0 /0 @:0 B@:0
Recv: ok
Changing monitoring state from 'Connecting' to 'Operational'
Recv: ok
Send: N1 M115*39
Recv: ok PROTOCOL_VERSION:0.1 FIRMWARE_NAME:Makerbot FIRMWARE_VERSION:7.2 FIRMWARE_URL:https://support.makerbot.com/learn/earlier-products/replicator-original/updating-firmware-for-the-makerbot-replicator-via-replicatorg_13302 MACHINE_TYPE:r2 EXTRUDER_COUNT:1
Send: N2 M21*18
Recv: ok
Recv: SD init fail
Send: M105
Recv: ok T:26 /0 B:0 /0 @:0 B@:0
Send: M105
Send: M105
Recv: ok T:25 /0 B:0 /0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:26 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:29 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:32 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:35 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:39 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:42 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:46 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:51 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:55 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:59 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:62 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:66 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:71 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:76 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:79 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:84 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:87 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:91 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:95 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:99 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:102 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:106 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:109 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:112 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:116 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:120 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:123 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:127 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:129 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:132 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:135 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:139 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:142 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:144 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:147 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:150 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:153 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:156 /230 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:159 /230 B:0 /0 @:0 B@:0
Send: M105
Unexpected error while writing to serial port: IOError: '[Errno 5] Input/output error' @ comm.py:_do_send_without_checksum:2499
Changing monitoring state from 'Operational' to 'Offline: IOError: '[Errno 5] Input/output error' @ comm.py:_do_send_without_checksum:2499'
Connected to: <GPX.gpxprinter.GpxPrinter instance at 0x6f46e1e8>, starting monitor
Recv: start
Recv: Makerbot v7.2
Recv: SD init fail
Recv: T:212 /212 B:0 /0 @:0 B@:0
Recv: ok
Recv: ok
Send: N1 M115*39
Send: N2 M21*18
Recv: ok
Recv: SD init fail
Send: M105
Recv: ok T:212 /212 B:0 /0 @:0 B@:0
Send: M105
Recv: ok T:211 /212 B:0 /0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Changing monitoring state from 'Operational' to 'Printing'
Recv: ok
Send: (@build "pushbtn-inst-225")
Recv: ok
Send: N1 M136 (pushbtn-inst-225)*84
Recv: ok
Send: ?1-pushbtn-inst-225??R???0????p?@??????4??@???????`?x
Unexpected error while writing to serial port: TypeError: 'must be string without null bytes, not str' @ comm.py:_do_send_without_checksum:2499
Changing monitoring state from 'Printing' to 'Offline: TypeError: 'must be string without null bytes, not str' @ comm.py:_do_send_without_checksum:2499'
Connected to: <GPX.gpxprinter.GpxPrinter instance at 0x6f4dd788>, starting monitor
Recv: start
Recv: Makerbot v7.2
Recv: SD init fail
Recv: ok
Send: N1 M105*38
Recv: ok
Send: N1 M115*39
Send: M21
Recv: ok
Recv: SD init fail
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Recv: ok T:213 /212 B:0 /0 @:0 B@:0
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
Send: M105
