I have BananaPi M3 board, which was succesfully running OctoPrint since 2 years. However some time ago I was able to update neither any plugin nor Octoprint's version itself.That's why decided to completly reinstall entire system +Octoprint to the latest one (currently 1.4.0). Previous version was runing under python 2.7 which those days is a not good choice.
System spec:
Operating System: Ubuntu 16.04.6 LTS
Kernel: Linux 3.4.39-BPI-M3-Kernel
Architecture: arm
Unfortunatelly it's the freshest one..
System is updated and upgrated. I have installed python 3.7.7 as well as pip3:
pi@bpi-iot-ros-ai:~ python -V
Python 2.7.12
pi@bpi-iot-ros-ai:~ python3 -V
Python 3.7.7
pi@bpi-iot-ros-ai:~ pip -V
pip 20.0.2 from /usr/local/lib/python2.7/dist-packages/pip (python 2.7)
pi@bpi-iot-ros-ai:~ pip3 -V
pip 20.0.2 from /home/pi/.local/lib/python3.7/site-packages/pip (python 3.7)
pi@bpi-iot-ros-ai:~$ update-alternatives --list python3
/usr/bin/python3.5
/usr/bin/python3.7
For pip3 I have had to implement a work around with alias (alias pip3='python3 -m pip'). Without that I received a following warning:
pi@bpi-iot-ros-ai:~$ pip3 -V
WARNING: pip is being invoked by an old script wrapper. This will fail in a future version of pip.
Please see https://github.com/pypa/pip/issues/5599 for advice on fixing the underlying issue.
To avoid this problem you can invoke Python with '-m pip' instead of running pip directly.
Virtualenv is already installed.
According to Octoprint installation guide from
- Checkout OctoPrint:
git clone https://github.com/OctoPrint/OctoPrint.git - Change into the OctoPrint folder:
cd OctoPrint - Create a user-owned virtual environment therein:
virtualenv venvif your system default python version is python 2.7, otherwise you need to specify the version explicitly, e.g.virtualenv --python=python2.7 venv. - Install OctoPrint into that virtual environment :
./venv/bin/pip install .
ed 3) While my default python version is 3.7 both:
virtualenv --python=python3.7 venv
virtualenv venv
are equal.
pi@bpi-iot-ros-ai:~/octoprint/OctoPrint$ virtualenv --python=python3.7 venv
created virtual environment CPython3.7.7.final.0-32 in 2334ms
creator CPython3Posix(dest=/home/pi/octoprint/OctoPrint/venv, clear=False, global=False)
seeder FromAppData(download=False, pip=latest, setuptools=latest, wheel=latest, via=copy, app_data_dir=/home/pi/.local/share/virtualenv/seed-app-data/v1.0.1)
activators BashActivator,CShellActivator,FishActivator,PowerShellActivator,PythonActivator,XonshActivator
pi@bpi-iot-ros-ai:~/octoprint/OctoPrint$ source venv/bin/activate
(venv) pi@bpi-iot-ros-ai:~/octoprint/OctoPrint$
So far so good.
ed 4) But here is a tricky part for me. How to solve following:
(venv) pi@bpi-iot-ros-ai:~/octoprint/OctoPrint$ ./venv/bin/pip install .
Processing /home/pi/octoprint/OctoPrint
Collecting flask<0.13,>=0.12
Using cached Flask-0.12.5-py2.py3-none-any.whl (81 kB)
Collecting Jinja2<2.9,>=2.8.1
Using cached Jinja2-2.8.1-py2.py3-none-any.whl (264 kB)
Processing /home/pi/.cache/pip/wheels/a2/45/43/36ec7a893e16c1212a6b1505ded0a2d73cf8e863a0227c8e04/tornado-4.5.3-cp37-cp37m-linux_armv7l.whl
Collecting regex!=2018.11.6
Using cached regex-2020.4.4.tar.gz (695 kB)
Processing /home/pi/.cache/pip/wheels/6b/b8/33/1da5a5d39e093a68d81848aa44fd70e3cd0193e6f2d5641052/Flask_Login-0.4.1-py2.py3-none-any.whl
Processing /home/pi/.cache/pip/wheels/4b/84/b6/a63a6e1b865e36aa4fcc9b6da4a7859608d89520d655012bfc/Flask_Babel-0.12.2-py3-none-any.whl
Processing /home/pi/.cache/pip/wheels/b1/5a/e3/5da3305348f63e71e5e5256c928bd72f53bdcefc9ec82139f6/Flask_Assets-0.12-py3-none-any.whl
Processing /home/pi/.cache/pip/wheels/22/f5/18/df711b66eb25b21325c132757d4314db9ac5e8dabeaf196eab/blinker-1.4-py3-none-any.whl
Collecting werkzeug<0.17,>=0.16
Using cached Werkzeug-0.16.1-py2.py3-none-any.whl (327 kB)
Collecting cachelib<0.2,>=0.1
Using cached cachelib-0.1-py3-none-any.whl (12 kB)
Processing /home/pi/.cache/pip/wheels/5e/03/1e/e1e954795d6f35dfc7b637fe2277bff021303bd9570ecea653/PyYAML-5.3.1-cp37-cp37m-linux_armv7l.whl
Collecting markdown<3.2,>=3.1
Using cached Markdown-3.1.1-py2.py3-none-any.whl (87 kB)
Collecting pyserial<3.5,>=3.4
Using cached pyserial-3.4-py2.py3-none-any.whl (193 kB)
Collecting netaddr<0.8,>=0.7.19
Using cached netaddr-0.7.19-py2.py3-none-any.whl (1.6 MB)
Processing /home/pi/.cache/pip/wheels/11/13/28/f1224b6031ddfaf72de630b6369c7ea0c59f1e3c3ce600d365/watchdog-0.9.0-py3-none-any.whl
Processing /home/pi/.cache/pip/wheels/84/11/b1/f064fa3c4d3cfa260926c057953e50d1249f12608297e0e0fa/sarge-0.1.5.post0-py3-none-any.whl
Collecting netifaces<0.11,>=0.10.9
Using cached netifaces-0.10.9.tar.gz (28 kB)
Processing /home/pi/.cache/pip/wheels/22/7d/12/2516ce8e4bf89664efdb91dee7c1162c874dca21dfd429ddfb/pylru-1.2.0-py3-none-any.whl
Collecting rsa<5,>=4.0
Using cached rsa-4.0-py2.py3-none-any.whl (38 kB)
Collecting pkginfo<1.6,>=1.5.0.1
Using cached pkginfo-1.5.0.1-py2.py3-none-any.whl (25 kB)
Collecting requests<3,>=2.22.0
Using cached requests-2.23.0-py2.py3-none-any.whl (58 kB)
Collecting semantic_version<2.9,>=2.8
Using cached semantic_version-2.8.4-py2.py3-none-any.whl (15 kB)
Collecting psutil<5.7,>=5.6.5
Using cached psutil-5.6.7.tar.gz (448 kB)
Collecting Click<8,>=7
Using cached click-7.1.1-py2.py3-none-any.whl (82 kB)
Processing /home/pi/.cache/pip/wheels/b3/66/bb/6379b15148128db97f0b59708ba1d767bf751a86ddf0c8e479/awesome_slugify-1.6.5-py3-none-any.whl
Processing /home/pi/.cache/pip/wheels/4a/87/a9/ef99b7b68f9816d5ef1262dc11ce31a93a844eb69e68c1a031/feedparser-5.2.1-py3-none-any.whl
Processing /home/pi/.cache/pip/wheels/56/b0/fe/4410d17b32f1f0c3cf54cdfb2bc04d7b4b8f4ae377e2229ba0/future-0.18.2-py3-none-any.whl
Collecting websocket-client<0.57,>=0.56
Using cached websocket_client-0.56.0-py2.py3-none-any.whl (200 kB)
Processing /home/pi/.cache/pip/wheels/23/5f/62/304b411f20be41821465a82bc98baabc5e68c3cdd1eb99db71/wrapt-1.11.2-py3-none-any.whl
Processing /home/pi/.cache/pip/wheels/f6/65/82/d742fe456cd8aa21ffe6c4c1eaeedf3c2d430689811bf328e1/emoji-0.5.4-py3-none-any.whl
Processing /home/pi/.cache/pip/wheels/68/17/69/ac196dd181e620bba5fae5488e4fd6366a7316dce13cf88776/frozendict-1.2-py3-none-any.whl
Collecting sentry-sdk==0.13.2
Using cached sentry_sdk-0.13.2-py2.py3-none-any.whl (91 kB)
Collecting filetype<2,>=1.0.5
Using cached filetype-1.0.6-py2.py3-none-any.whl (15 kB)
Collecting itsdangerous>=0.21
Using cached itsdangerous-1.1.0-py2.py3-none-any.whl (16 kB)
Processing /home/pi/.cache/pip/wheels/b9/d9/ae/63bf9056b0a22b13ade9f6b9e08187c1bb71c47ef21a8c9924/MarkupSafe-1.1.1-py3-none-any.whl
Collecting Babel>=2.3
Using cached Babel-2.8.0-py2.py3-none-any.whl (8.6 MB)
Collecting webassets>=0.11.1
Using cached webassets-2.0-py3-none-any.whl (142 kB)
Requirement already satisfied: setuptools>=36 in ./venv/lib/python3.7/site-packages (from markdown<3.2,>=3.1->OctoPrint==1.4.0) (46.1.3)
Processing /home/pi/.cache/pip/wheels/3e/31/09/fa59cef12cdcfecc627b3d24273699f390e71828921b2cbba2/pathtools-0.1.2-py3-none-any.whl
Collecting argh>=0.24.1
Using cached argh-0.26.2-py2.py3-none-any.whl (30 kB)
Collecting pyasn1>=0.1.3
Using cached pyasn1-0.4.8-py2.py3-none-any.whl (77 kB)
Collecting chardet<4,>=3.0.2
Using cached chardet-3.0.4-py2.py3-none-any.whl (133 kB)
Collecting urllib3!=1.25.0,!=1.25.1,<1.26,>=1.21.1
Using cached urllib3-1.25.9-py2.py3-none-any.whl (126 kB)
Collecting idna<3,>=2.5
Using cached idna-2.9-py2.py3-none-any.whl (58 kB)
Collecting certifi>=2017.4.17
Using cached certifi-2020.4.5.1-py2.py3-none-any.whl (157 kB)
Collecting Unidecode<0.05,>=0.04.14
Using cached Unidecode-0.04.21-py2.py3-none-any.whl (228 kB)
Collecting six
Using cached six-1.14.0-py2.py3-none-any.whl (10 kB)
Collecting pytz>=2015.7
Using cached pytz-2019.3-py2.py3-none-any.whl (509 kB)
Building wheels for collected packages: OctoPrint, regex, netifaces, psutil
Building wheel for OctoPrint (setup.py) ... done
Created wheel for OctoPrint: filename=OctoPrint-1.4.0-py2.py3-none-any.whl size=3114118 sha256=b1193131ba187c22072942a49cc04ec2e42611e1594fb8e669cdee351653f3b2
Stored in directory: /tmp/pip-ephem-wheel-cache-5x5_zg1e/wheels/f7/84/0f/35bfd3b71a3ed985eef521216c1e017668e928880f4862f5a9
Building wheel for regex (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: /home/pi/octoprint/OctoPrint/venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-9m4sze3w/regex/setup.py'"'"'; file='"'"'/tmp/pip-install-9m4sze3w/regex/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-9vmnl956
cwd: /tmp/pip-install-9m4sze3w/regex/
Complete output (18 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.7
creating build/lib.linux-armv7l-3.7/regex
copying regex_3/init.py -> build/lib.linux-armv7l-3.7/regex
copying regex_3/regex.py -> build/lib.linux-armv7l-3.7/regex
copying regex_3/_regex_core.py -> build/lib.linux-armv7l-3.7/regex
copying regex_3/test_regex.py -> build/lib.linux-armv7l-3.7/regex
running build_ext
building 'regex._regex' extension
creating build/temp.linux-armv7l-3.7
creating build/temp.linux-armv7l-3.7/regex_3
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -I/home/pi/octoprint/OctoPrint/venv/include -I/usr/include/python3.7m -c regex_3/_regex.c -o build/temp.linux-armv7l-3.7/regex_3/_regex.o
regex_3/_regex.c:48:20: fatal error: Python.h: No such file or directory
compilation terminated.
error: command 'arm-linux-gnueabihf-gcc' failed with exit status 1
ERROR: Failed building wheel for regex
Running setup.py clean for regex
Building wheel for netifaces (setup.py) ... error
command: /home/pi/octoprint/OctoPrint/venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-9m4sze3w/netifaces/setup.py'"'"'; file='"'"'/tmp/pip-install-9m4sze3w/netifaces/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-3e1g1i5_
cwd: /tmp/pip-install-9m4sze3w/netifaces/
running bdist_wheel
running build
running build_ext
checking for getifaddrs...found.
checking for getnameinfo...found.
checking for IPv6 socket IOCTLs...not found.
checking for optional header files...netash/ash.h netatalk/at.h netax25/ax25.h neteconet/ec.h netipx/ipx.h netpacket/packet.h linux/irda.h linux/atm.h linux/llc.h linux/tipc.h linux/dn.h.
checking whether struct sockaddr has a length field...no.
checking which sockaddr_xxx structs are defined...at ax25 in in6 ipx un ash ec ll atmpvc atmsvc dn irda llc.
checking for routing socket support...no.
checking for sysctl(CTL_NET...) support...no.
checking for netlink support...yes.
will use netlink to read routing table
building 'netifaces' extension
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DNETIFACES_VERSION=0.10.9 -DHAVE_GETIFADDRS=1 -DHAVE_GETNAMEINFO=1 -DHAVE_NETASH_ASH_H=1 -DHAVE_NETATALK_AT_H=1 -DHAVE_NETAX25_AX25_H=1 -DHAVE_NETECONET_EC_H=1 -DHAVE_NETIPX_IPX_H=1 -DHAVE_NETPACKET_PACKET_H=1 -DHAVE_LINUX_IRDA_H=1 -DHAVE_LINUX_ATM_H=1 -DHAVE_LINUX_LLC_H=1 -DHAVE_LINUX_TIPC_H=1 -DHAVE_LINUX_DN_H=1 -DHAVE_SOCKADDR_AT=1 -DHAVE_SOCKADDR_AX25=1 -DHAVE_SOCKADDR_IN=1 -DHAVE_SOCKADDR_IN6=1 -DHAVE_SOCKADDR_IPX=1 -DHAVE_SOCKADDR_UN=1 -DHAVE_SOCKADDR_ASH=1 -DHAVE_SOCKADDR_EC=1 -DHAVE_SOCKADDR_LL=1 -DHAVE_SOCKADDR_ATMPVC=1 -DHAVE_SOCKADDR_ATMSVC=1 -DHAVE_SOCKADDR_DN=1 -DHAVE_SOCKADDR_IRDA=1 -DHAVE_SOCKADDR_LLC=1 -DHAVE_PF_NETLINK=1 -I/home/pi/octoprint/OctoPrint/venv/include -I/usr/include/python3.7m -c netifaces.c -o build/temp.linux-armv7l-3.7/netifaces.o
netifaces.c:1:20: fatal error: Python.h: No such file or directory
ERROR: Failed building wheel for netifaces
Running setup.py clean for netifaces
Building wheel for psutil (setup.py) ... error
command: /home/pi/octoprint/OctoPrint/venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-9m4sze3w/psutil/setup.py'"'"'; file='"'"'/tmp/pip-install-9m4sze3w/psutil/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' bdist_wheel -d /tmp/pip-wheel-duqznice
cwd: /tmp/pip-install-9m4sze3w/psutil/
Complete output (42 lines):
running bdist_wheel
running build
running build_py
creating build
creating build/lib.linux-armv7l-3.7/psutil
copying psutil/_psposix.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/init.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/_pssunos.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/_psaix.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/_compat.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/_pswindows.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/_psosx.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/_pslinux.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/_psbsd.py -> build/lib.linux-armv7l-3.7/psutil
copying psutil/_common.py -> build/lib.linux-armv7l-3.7/psutil
creating build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_linux.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_sunos.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/init.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_windows.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_connections.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_bsd.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_system.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_osx.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_memory_leaks.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_unicode.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_contracts.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/runner.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_posix.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_process.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_misc.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/main.py -> build/lib.linux-armv7l-3.7/psutil/tests
copying psutil/tests/test_aix.py -> build/lib.linux-armv7l-3.7/psutil/tests
running build_ext
building 'psutil._psutil_linux' extension
creating build/temp.linux-armv7l-3.7/psutil
arm-linux-gnueabihf-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DPSUTIL_POSIX=1 -DPSUTIL_VERSION=567 -DPSUTIL_LINUX=1 -I/home/pi/octoprint/OctoPrint/venv/include -I/usr/include/python3.7m -c psutil/_psutil_common.c -o build/temp.linux-armv7l-3.7/psutil/_psutil_common.o
psutil/_psutil_common.c:9:20: fatal error: Python.h: No such file or directory
ERROR: Failed building wheel for psutil
Running setup.py clean for psutil
Successfully built OctoPrint
Failed to build regex netifaces psutil
Installing collected packages: Click, itsdangerous, MarkupSafe, Jinja2, werkzeug, flask, tornado, regex, Flask-Login, pytz, Babel, Flask-Babel, webassets, Flask-Assets, blinker, cachelib, PyYAML, markdown, pyserial, netaddr, pathtools, argh, watchdog, sarge, netifaces, pylru, pyasn1, rsa, pkginfo, chardet, urllib3, idna, certifi, requests, semantic-version, psutil, Unidecode, awesome-slugify, feedparser, future, six, websocket-client, wrapt, emoji, frozendict, sentry-sdk, filetype, OctoPrint
Running setup.py install for regex ... error
command: /home/pi/octoprint/OctoPrint/venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-9m4sze3w/regex/setup.py'"'"'; file='"'"'/tmp/pip-install-9m4sze3w/regex/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' install --record /tmp/pip-record-euq2_a8h/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/octoprint/OctoPrint/venv/include/site/python3.7/regex
running install
running build
running build_py
creating build
running build_ext
ERROR: Command errored out with exit status 1: /home/pi/octoprint/OctoPrint/venv/bin/python -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-9m4sze3w/regex/setup.py'"'"'; file='"'"'/tmp/pip-install-9m4sze3w/regex/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(file);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, file, '"'"'exec'"'"'))' install --record /tmp/pip-record-euq2_a8h/install-record.txt --single-version-externally-managed --compile --install-headers /home/pi/octoprint/OctoPrint/venv/include/site/python3.7/regex Check the logs for full command output.
You saved my work, one more time big thanks!
