I had it connected to the micro usb port, like my Pi Zero. Whoops.
Used the normal USB ports, now seeing ttyUSB0, but still not connecting. System told me brltty wasn't installed.
Unplugged USB, replugged, ran:
sudo dmesg | tail -n 20
Output:
[ 87.965415] fuse init (API version 7.26)
[ 91.852693] asoc-aml-card odroid_hdmi: S/PDIF Playback disable
[ 91.852775] spdif_a keep clk continuous
[ 91.852781] aml_spdif_close
[ 91.852837] audio_ddr_mngr: frddrs[0] released by device ff660000.audiobus:spdif@0
[ 123.670652] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 0 to 9600
[ 123.678430] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 9600 to 115200
[ 123.739331] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 115200
[ 123.744573] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 115200
[ 129.930719] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 115200
[ 129.930800] meson_uart ffd24000.serial: ttyS1 use xtal(24M) 24000000 change 115200 to 250000
[ 593.843103] usb 1-1.3: USB disconnect, device number 4
[ 593.844441] ch341-uart ttyUSB0: ch341-uart converter now disconnected from ttyUSB0
[ 593.844722] ch341 1-1.3:1.0: device disconnected
[ 598.210320] usb 1-1.3: new full-speed USB device number 5 using xhci-hcd
[ 598.360043] usb 1-1.3: New USB device found, idVendor=1a86, idProduct=7523
[ 598.360049] usb 1-1.3: New USB device strings: Mfr=0, Product=2, SerialNumber=0
[ 598.360051] usb 1-1.3: Product: USB Serial
[ 598.386500] ch341 1-1.3:1.0: ch341-uart converter detected
[ 598.387632] usb 1-1.3: ch341-uart converter now attached to ttyUSB0
root@odroid:/home/octo#
Noticed this in the terminal:
Connecting to port /dev/ttyUSB0, baudrate 115200
Handshake attempt #1 with timeout 2.0s
Connected to: Serial<id=0x7f59e14730, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Recv:
Handshake attempt #2 with timeout 2.0s
Send: N0 M110 N0125
Recv: mkspi login: N0 M110 N0125
Recv: Password:
Recv: N0 M110 N0125
I then blacklisted the other ports and tried connecting again, with manual settings and saw this:
Trying port /dev/ttyUSB0, baudrate 57600
Send: N0 M110 N0125
Send: N0 M110 N0125
Handshake attempt #3 with timeout 2.0s
Send: N0 M110 N0*125
Recv:
\x8a 11 *12Ðass÷ïòdº §Q}Qk'¸W\x8e\x8a\x0c\x9d\x98X×÷×z\x1d\x98«ÏÌ8>e¨D\x8fήî\x9fæÍ\x8fÍå\x8fÙ³¾\x8d]æÍÍ8®}æÍ\x8fÍç\x1eØ<Í\x8díÅßą̊vè\x0ce<w\x9fÖóæÍ\x9e?\x7fG\x85͸|ßÎEßDÍßæÍ\x0e\x8fÍ\x85Í\x98ç]x\x0cÅ~óõë\x85DÅæÍÏë\x85g\x88\x9dþ\x98Dí¨\x0ce?uõêïÏô}Í\x88DÅÌw£?u\x85\x0cý~Ý>ßü]ë>xøW\x8b몿ù¨ß¾\x1a\x0c
èTó«×Êe\x98ÇĮ̈\x8ee8D\x8fÎvî\x9f®Í\x8fÍ\x85\x8fÙÓ¾\x8d]æÍÍ8®}æÍ\x8f5å\x1eÈ\x8cÍ}eų\x85̨\x9e8\x04Å\x8cϯÖ\x9f®mÖÏ\x8fçåͨì³\x8eÍã\x0c=Ç®}\x8e?u\x85Í\x88ç~\x0ce~Ïõë\x85DÅæÍ<ë\x85\x1fø\x9dÖ¨Dí\x87\x8d;\x8fÍÅÆ«?\x88ÍÕø\x0cÅ\w×=uå\x0cýÎÝ>Çü]ë>xøW\x8bëEªo¨W\x8e\x1a|\x9dèÈ׫óze¨«\x1f<8\x8eŨ
Trying port /dev/ttyUSB0, baudrate 38400
Changed USB cables, removed wifi adapter, tried auto connecting again. Saw:
Send: N0 M110 N0125
Recv: \x1cüàüàü\x00\x1c\x1c\x1cüàüàü\x00\x1cà\x00\x1cüàüàü\x00\x1c\x1c\x00\x00\x00à\x00\x00\x00\x00à\x00\x00\x00\x00à\x00\x00\x00à\x00\x00\x00\x00à\x00\x00\x00à\x00\x00\x00\x00à\x00\x00;;\x03\x8foç8#o\x8fç\x1c\x1cÄ\x1cã\x9cÇ<\x1c\x9cãßÄo\x9f<ïç\x1c Ûï\x0fß\x1b\x8f\x0f\x1cߨoï{\x1c\x00\x9cà\x03;;ïç<Àoç\x1cççÜ#\x8fç\x1f\x00ü\x03\x07üÀ\xffû/ÝUÕï¸W\x8e\x8a\x0c\x9d\x98X×÷×éë¡«Ï<8.ŨD\x7f~®F³fÍ?ue³÷³9õÍ÷3ͨ\x0cfÍ®}?Í\x85f\x88<5\x8díõßeL¨vè\x0ceu<u¯V³f}\x9eO\x8fse=¸ìÙó¾Ñ¾\x87\x0b=Es}ÞýueÍ\x88çè\x0ceù«V\x7f¾\x98DÅQÍÏ«\x85\x1aø\x9dV¨Dí\x85\x8dU=Í;F«=ÑÍÝøDÅ1uÓýu\x85\x0cý~Ý\x0eÝñ«ù!\x9aNþÎ<®¨ê\x8a\x89Qí(E«}\x17\x8aÂÂEFí³\x8aþ
WARNThe received line contains at least one null byte character at position 6, this hints at some data corruption going on
Recv: Armbian 22.05.0-trunk Buster ttyS2
Recv:
Send: N0 M110 N0125
Recv: mkspi login:
Recv: Password:
Send: N0 M110 N0125
Recv: N0 M110 N0125
Trying port /dev/ttyUSB0, baudrate 19200
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying port /dev/ttyUSB0, baudrate 9600
Send: N0 M110 N0125
Send: N0 M110 N0125
Changing monitoring state from "Detecting serial connection" to "Error"
Changed cables:
Performing autodetection with 7 port/baudrate candidates: /dev/ttyUSB0@115200, /dev/ttyUSB0@250000, /dev/ttyUSB0@230400, /dev/ttyUSB0@57600, /dev/ttyUSB0@38400, /dev/ttyUSB0@19200, /dev/ttyUSB0@9600
Trying port /dev/ttyUSB0, baudrate 115200
Connected to: Serial<id=0x7f5808d940, open=True>(port='/dev/ttyUSB0', baudrate=115200, bytesize=8, parity='N', stopbits=1, timeout=2.0, xonxoff=False, rtscts=False, dsrdtr=False), starting monitor
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying port /dev/ttyUSB0, baudrate 250000
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Trying port /dev/ttyUSB0, baudrate 230400
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Send: N0 M110 N0125
Recv: \x1cüàüàü\x00\x1c\x1c\x1cüàüàü\x00\x1c\x1c\x1cüàüàü\x00\x1c\x1c\x00\x00\x00à\x00\x00\x00à\x00\x00\x00\x00à\x00\x00\x00\x00à\x00\x00\x00\x00à\x00\x00\x00à\x00\x00\x00\x00à\x00\x00;;\x03\x8foç8#o\x8fç\x1c\x1cÄ\x1cã\x9cÇ<\x1c\x9cãßÄoß<ïç\x1c Ûï\x0fß\x1b\x8f\x0f\x1cߨoï{\x1c\x00\x9cà\x03;;ïç<Àoç\x1cççÜ#\x8fç\x1f\x00ü\x03\x07üð\xff÷\xff\xffUUê+ÙÕ´ß¾\x8a\x0c
\x90X³÷×Ùëa«Ï58>ŨD\x8f~®F³fÍ?uE³÷³ÎõÍ÷º®\x1dÍèfÍ®}\x8fÍ\x85fØ<5\x8díEßęv0\x0ceñ}¯V³®}\x9eÏ\x8f3e=¨ì÷³¾\xff¾³\x0c=ÝsÍ\x0eýÍ\x85Í\x98ç]xDÅ9³õçe>¨ìs}?çeg\x88V\x98\x0cí¨DeýuUîïýá}\x8d\x88\x08eqÍ£ÑÍeDõÎ\x8d>EÑ]çùáÂÎþÎ5®\x98ê\x8a\x89Qí(E«}\x17\x8aB\x9aåFíÏ\x8aþ
Changed USB ports, same error, same baud rate.
