So, I'm following along with this tutorial, and for some reason I cannot get the udev rules to work.
- Adding various things to each line int he udev rules
- Looking at the results of the 'diff' command, and adding more and more things to each line
Here are my device differences.
--- devInfoUSU0 2018-11-04 00:46:29.022765830 -0400
+++ devInfoUSU1 2018-11-04 00:46:37.423037462 -0400
@@ -5,61 +5,95 @@
A rule to match, can be composed by the attributes of the device
and the attributes from one single parent device.
- looking at device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/1-1.2:1$
- KERNEL=="ttyUSB0"
+ looking at device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/1-1.1.2$
+ KERNEL=="ttyUSB1"
SUBSYSTEM=="tty"
DRIVER==""
- looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2/$
- KERNELS=="ttyUSB0"
+ looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1/$
+ KERNELS=="ttyUSB1"
SUBSYSTEMS=="usb-serial"
- DRIVERS=="ch341-uart"
+ DRIVERS=="ftdi_sio"
+ ATTRS{latency_timer}=="16"
ATTRS{port_number}=="0"
- KERNELS=="1-1.2:1.0"
+ KERNELS=="1-1.1.2:1.0"
SUBSYSTEMS=="usb"
- DRIVERS=="ch341"
ATTRS{authorized}=="1"
ATTRS{bAlternateSetting}==" 0"
ATTRS{bInterfaceClass}=="ff"
ATTRS{bInterfaceNumber}=="00"
- ATTRS{bInterfaceProtocol}=="02"
- ATTRS{bInterfaceSubClass}=="01"
- ATTRS{bNumEndpoints}=="03"
+ ATTRS{bInterfaceProtocol}=="ff"
+ ATTRS{bInterfaceSubClass}=="ff"
+ ATTRS{bNumEndpoints}=="02"
+ ATTRS{interface}=="FT232R USB UART"
ATTRS{supports_autosuspend}=="1"
- looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.2':
- KERNELS=="1-1.2"
+ KERNELS=="1-1.1.2"
SUBSYSTEMS=="usb"
DRIVERS=="usb"
ATTRS{avoid_reset_quirk}=="0"
ATTRS{bConfigurationValue}=="1"
- ATTRS{bDeviceClass}=="ff"
+ ATTRS{bDeviceClass}=="00"
ATTRS{bDeviceProtocol}=="00"
ATTRS{bDeviceSubClass}=="00"
ATTRS{bMaxPacketSize0}=="8"
- ATTRS{bMaxPower}=="96mA"
+ ATTRS{bMaxPower}=="90mA"
ATTRS{bNumConfigurations}=="1"
ATTRS{bNumInterfaces}==" 1"
- ATTRS{bcdDevice}=="0254"
- ATTRS{bmAttributes}=="80"
+ ATTRS{bcdDevice}=="0600"
+ ATTRS{bmAttributes}=="a0"
ATTRS{busnum}=="1"
ATTRS{configuration}==""
- ATTRS{devnum}=="4"
- ATTRS{devpath}=="1.2"
+ ATTRS{devnum}=="5"
+ ATTRS{devpath}=="1.1.2"
ATTRS{devspec}==" (null)"
- ATTRS{idProduct}=="7523"
- ATTRS{idVendor}=="1a86"
+ ATTRS{idProduct}=="6001"
+ ATTRS{idVendor}=="0403"
ATTRS{ltm_capable}=="no"
+ ATTRS{manufacturer}=="FTDI"
ATTRS{maxchild}=="0"
- ATTRS{product}=="USB2.0-Serial"
+ ATTRS{product}=="FT232R USB UART"
ATTRS{quirks}=="0x0"
ATTRS{removable}=="removable"
+ ATTRS{serial}=="AK065FIZ"
ATTRS{speed}=="12"
- ATTRS{urbnum}=="14"
- ATTRS{version}==" 1.10"
+ ATTRS{urbnum}=="1957326"
+ ATTRS{version}==" 2.00"
+ looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1/1-1.1':
+ KERNELS=="1-1.1"
+ SUBSYSTEMS=="usb"
+ DRIVERS=="usb"
+ ATTRS{authorized}=="1"
+ ATTRS{avoid_reset_quirk}=="0"
+ ATTRS{bConfigurationValue}=="1"
+ ATTRS{bDeviceClass}=="09"
+ ATTRS{bDeviceProtocol}=="02"
+ ATTRS{bDeviceSubClass}=="00"
+ ATTRS{bMaxPacketSize0}=="64"
+ ATTRS{bMaxPower}=="2mA"
+ ATTRS{bNumConfigurations}=="1"
+ ATTRS{bNumInterfaces}==" 1"
+ ATTRS{bcdDevice}=="0bb3"
+ ATTRS{bmAttributes}=="e0"
+ ATTRS{busnum}=="1"
+ ATTRS{configuration}==""
+ ATTRS{devnum}=="3"
+ ATTRS{devpath}=="1.1"
+ ATTRS{idProduct}=="2514"
+ ATTRS{idVendor}=="0424"
+ ATTRS{ltm_capable}=="no"
+ ATTRS{maxchild}=="3"
+ ATTRS{quirks}=="0x0"
+ ATTRS{removable}=="fixed"
+ ATTRS{speed}=="480"
+ ATTRS{urbnum}=="60"
looking at parent device '/devices/platform/soc/3f980000.usb/usb1/1-1':
KERNELS=="1-1"
@@ -155,7 +189,7 @@
ATTRS{inv_sel_hsic}=="Invert Select HSIC = 0x0"
ATTRS{mode}=="Mode = 0x1"
ATTRS{mode_ch_tim_en}=="Mode Change Ready Timer Enable = 0x0"
- ATTRS{rd_reg_test}=="Time to read GNPTXFSIZ reg 10000000 times: 920 msecs (92 jiffies)"
+ ATTRS{rd_reg_test}=="Time to read GNPTXFSIZ reg 10000000 times: 870 msecs (87 jiffies)"
ATTRS{regdump}=="Register Dump"
ATTRS{regoffset}=="0xffffffff"
ATTRS{regvalue}=="invalid offset"
Here is my udev 99-usb.rules:
SUBSYSTEM=="tty", DRIVERS=="ch341-uart", ATTRS{interface}=="FT232R USB UART", ATTRS{product}=="FT232R USB UART", SYMLINK+="ttySTARTT"
SUBSYSTEM=="tty", DRIVERS=="ftdi_sio", ATTRS{product}=="USB2.0-Serial", SYMLINK+="ttyEnder3"
