re posting as new thread
Hello,
I am new to octoprint.
It works from time to time but UI is very unstable/flickering/frozen and connection to printer unstable.
I initially thought the printer connection was the issue and tried many many cables but now realised that even without printer connected there is a UI issue.
It is unresponsive and flickers, for example in safe mode the safe mode popup keeps on showing up/blinking. When I try to delete a file, the button is unresponsive and flickering lightly.
fyi connection to pi is perfect, ping, ssh and camera feed.
I have tried different browsers.
I have looked at FAQ UI frozen guide.
YES, still flickering, including safe mode popup
NO
Complete Logs
Serial log, nothing as it happens even without a printer connected
octoprint log, this is repeated endlessly
2021-02-11 03:34:36,671 - octoprint.server.util.sockjs - INFO - Client connection closed: 240b:XXX:2901
2021-02-11 03:34:37,261 - octoprint.server.util.sockjs - INFO - New connection from client: 240b:XXX:2901
2021-02-11 03:34:37,282 - octoprint.server.util.flask - INFO - Passively logging in user ysiegel from 240b:XXX:2901
2021-02-11 03:34:37,282 - octoprint.access.users - INFO - Logged in user: my login
Browser
Even when I do nothing there are constant message flows in console (may be normal... no clue!)
In console I get the below repeating at high speed:
Safe mode is active. Third party plugins and language packs are disabled and cannot be enabled.
packed_core.js?8f90e417:840
Reason for safe mode: settings
packed_core.js?8f90e417:844 Triggering connect on all view models
packed_core.js?8f90e417:846 Server (re)connect processed
packed_core.js?8f90e417:839 Connected to the server
in Network I get this constantly repeating at high speed:
login:
1. Request URL:
http://octopi.local/api/login
2. Request Method:
POST
3. Status Code:
200 OK
file?recursive=true
1. Request URL:
http://octopi.local/api/files?recursive=true
2. Request Method:
GET
3. Status Code:
304 NOT MODIFIED
info?t=1613013498537
1. Request URL:
http://octopi.local/sockjs/info?t=1613013498537
2. Request Method:
GET
3. Status Code:
200 OK
websocket:
1. Request URL:
ws://octopi.local/sockjs/285/jrfl1zyh/websocket
2. Request Method:
GET
3. Status Code:
101 Switching Protocols
octoprint.version : 1.5.3
browser.user_agent : Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/80.0.3987.149 Safari/537.36
MacOS
Pi 4
Ender 3 but it does not seem to be relevant...
